Vida CEM swapping
WhizzMan
Year and Model: 2001 XC70
Re: Vida CEM swapping
Post by WhizzMan »
As long as no solution has been found for < 2005 CEM-B, maybe someone could put in a fall back brute force algorithm? At least there would be some way for us to get our pin code.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 604 times
Post by vtl »
For 250 KBaud CAN bus the direct attack on 6 bytes would take up to 42 years.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
WhizzMan wrote: 15 Aug 2021, 04:01 As long as no solution has been found for < 2005 CEM-B, maybe someone could put in a fall back brute force algorithm? At least there would be some way for us to get our pin code.
100E6 = 1E12 possible pins.
1E12 / 750 pins per second = 1,333,333,333.333 seconds.
1,333,333,333.333 seconds / 60 = 22,222,222.222 minutes.
22,222,222.222 minutes / 60 = 370,370.370 hours.
370,370.370 hours / 168 = 2,204.586 weeks.
2,204.586 weeks / 52 = 42.396 years.
If you lose power you will need to start over again.
Time to brute force at 750 pins per second by number of bytes.
# of bytes --- Time
1 100E1 / 750 = 0.133 s
2 100E2 / 750 = 13.333 s
3 100E3 / 750 = 1333.33 s
4 100E4 / 750 = 133,333.333 s
5 100E5 / 750 = 13,333,333.333 s
6 100E6 / 750 = 1,333,333,333.333 s
The cracker figures the first three bytes by analyzing the response behavior. It is analogous to playing Poker with a MCU. You deduce what "cards" it holding by observing superficial behavior characteristics. With three known bytes, brute force time is reduced to the time for 3 bytes.
mikeak2001
Year and Model: S70 1998 T5
Has thanked: 3 times
Been thanked: 28 times
Post by mikeak2001 »
File reverse engineering
Hi everyone, wondering if anyone can help.
I am having major trouble trying to crack the pin on the p1 cem that I have.
I have checked, double checked and tripple checked my pcb. I have analyzed it many times with picoscope etc. I have full comms on the bench, reads the part number, calculates an average latency of 66us, it go's through all the motions but then fails at the end.
I have tried everything from latency only to both latency and std, I have tried everything from 10 samples all the way to 100 samples.
Has anyone used Ghidra to reverse engineer the 9s12 files? I have reversed x86 in the past but never dealt with page files. This is throwing me off. A pointer would be awesome so that I can push my own learning experience. If I can get the pincode then I can try and send that code, If it still doesn't work then I know its my setup.
I have uploaded the binary files that I read off the cem with Xprog.
If anyone could flash a p1 cem and try to crack this file it would then confirm that it's my setup.
This thread has provided locations of the pin code however my files do not match up. I do know the files to be correct though because they have been flashed to a vehicle needing a second hand cem.
C30CemFiles.rar
RickHaleParker
mikeak2001 wrote: 15 Aug 2021, 13:14 I have uploaded the binary files that I read off the cem with Xprog.
Go to page 12. Sirloins shows where the PIN is located in a P1 bin file.
mikeak2001
RickHaleParker wrote: 15 Aug 2021, 14:16Go to page 12. Sirloins shows where the PIN is located in a P1 bin file.
Thanks for the pointer, I saw this but it doesn't seem to apply to my file.
This is what I have at location FBEF8.
RickHaleParker
mikeak2001 wrote: 15 Aug 2021, 14:44 Thanks for the pointer, I saw this but it doesn't seem to apply to my file.
Can't be right. The bytes are 8 bit BCD. The byte range is 00 - 99. What is at FBEF8 in the other files?
mikeak2001
RickHaleParker wrote: 15 Aug 2021, 14:58
Just been doing some analysis.
I have early files up to 2009
I also have files from 2010 on.
This is a file from 2009
Can anyone else please check files from 2010 on in a p1? It appears to me the pin code is not in that position in the 2010 on files. I can't crack any of the files from 2010 on.
RickHaleParker
mikeak2001 wrote: 15 Aug 2021, 15:31 Can anyone else please check files from 2010 on in a p1? It appears to me the pin code is not in that position in the 2010 on files. I can't crack any of the files from 2010 on.
I have a vague memory of somebody saying the later P1s have a different transposition order ( shuffle order ) for encrypting the PIN. That could be why 2010- is not cracking.
I think some of the P1s have no transposition order for encrypting the PIN ( 0,1,2,3,4,5 = 0, 1,2,3,4,5 ) .
vtl
Post by vtl »
Any of these BCD sequences look like a pin?
Code: Select all
$ gcc -o pin pin.c && ./pin 1M84E\ Secured\ Flash.bin 2 | egrep -a " fb[0-9a-f]+"
offset fb000: 48 50 41 50 47 34 : HPAPG4
offset fb10c: 48 49 48 41 00 00 : HIHA
offset fb120: 36 01 00 01 00 50 : 6P
offset fb9a4: 23 01 20 03 18 69 : # i
offset fbe64: 32 35 34 37 35 30 : 254750
offset fbe68: 35 30 20 41 44 00 : 50 AD
offset fbeb4: 31 25 47 49 00 00 : 1%GI
offset fbeb8: 00 00 09 39 30 85 : 	90�
offset fbebc: 30 85 00 31 25 47 : 0�1%G
The full dump is rather long, but you may want to look at it if none of the above sequences are your pin.
