Moaning wheel noise? Topic is solved
- Has thanked: 2856 times
- Been thanked: 1332 times
If it's from a grabbing caliper or parking brake, the wheel will be very hot after a long drive. Or even glowing hot, which makes diagnosis so much easier.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
All rotors have some runout. If the brake caliper or parking cable is binding slightly, as the speed increases it will creating a slight gap so the noise will go away. When the brake is depressed the cycle starts again with low speed noise till the runout increases the gap between the rotor and pads.
Check the parking brake cable for binding and lubricate then move on to caliper piston and lastly guide pins for the caliper.
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
I suspect that if I took the wheel off inspected some things and put it back together, it would disappear.MoVolvos wrote: 18 Aug 2021, 13:55 *
All U.S. market models.
All running and on the road.
- MoVolvos
Inspect, clean, adjust, repair as needed and you might hit the spot making the noise. Sometimes it's not obvious.Eddystone wrote: 18 Aug 2021, 20:05I suspect that if I took the wheel off inspected some things and put it back together, it would disappear.MoVolvos wrote: 18 Aug 2021, 13:55 *
- Has thanked: 311 times
- Been thanked: 817 times
Wouldn't want it to disappear, then you won't ever know what it was!Eddystone wrote: 18 Aug 2021, 20:05I suspect that if I took the wheel off inspected some things and put it back together, it would disappear.MoVolvos wrote: 18 Aug 2021, 13:55 *
- 998 Views
Last post by jonesboy1983
- 1430 Views
Last post by pmc2411
- 1187 Views
Last post by whatgoeson
- 13 Replies
- 3596 Views
- 540 Views
Last post by Doc67
