2007 Volvo XC90 V8 4.4 with 102k miles
It's in great shape needs alittle tlc here and there but
My A/C ... Here's some symptoms
When started I sometimes starts cool or warm .
Sometimes if warm it can get cool...
Sometimes cool but then can go out .
It does get cold when it rain
The air coming out can get pretty humid
I've checked the pressure...it is at the red .. I've had the truck for almost a year now...
Any suggestions ?
I'm thinking of evacuating and refill the refrigerate, or should I save my money.
Great appreciate any advice .. I've had a few Volvos and pretty confident in my knowledge but I always like to hear a second opinion.. thanks
A/C... Yah I know..
Masscomguru
- Year and Model: 2010 XC90 V8
- Been thanked: 16 times
It’s the control valve in the compressor. Very common, very easy to replace. It’s about 100 bucks from your favorite online volvo parts dealer. Get the system evacuated, replace the valve and have it charged up again.
- Has thanked: 1614 times
- Been thanked: 4078 times
Check the clutch gap at the compressor. Too large, and you will get the cold-warm scenario
The store can gauges are notoriously inaccurate. Check with a manifold set to measure the low/ high ratio which will point to charge or compressor problems
Masscomguru
It’s a variable displacement compressor. The clutch wear in the V8 and 3.2 models is very minimal. The issue is that the control valve is not monitored so the brain thinks it’s sending the correct voltage to move the valve, the valve doesn’t move. I actually don’t believe that the breadclip/shimming trick will work with these compressors.
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
No solenoid clutch to bread-clip (or tie-wrap) on the V8 and 3.2 motors.
My bet's on the control valve as noted above, having done a replacement myself a month or so ago with excellent results (consistent cold air). PN is 31305844.
edit- typos
edit- typos
ylwgto
- Year and Model: 2009 xc90 3.2 R
- Has thanked: 9 times
- Been thanked: 7 times
just went through this. Was going to replace just the control valve, but the car has almost 130K so I spent $100 more and got a new compressor, installed it, had it recharged and now it is steadily ice cold.
2009 XC90 3.2 R-Design 150K
Masscomguru
On the V8 you need raise the engine or pull the radiator to get the compressor out..
ylwgto
Missed the V8 detail!Masscomguru wrote: 19 Aug 2021, 14:32 On the V8 you need raise the engine or pull the radiator to get the compressor out..
maybe better to pull the controller without pulling the compressor if possible...
- 855 Views
Last post by hypo
- 13 Replies
- 6234 Views
Last post by esl_97_850_T5
- 795 Views
Last post by precopster
- 1130 Views
Last post by carboncow
- 987 Views
