Looking For Pasty Dry-Quick Glue
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Post by Oka »
1. What would be the best way to clue this down?
2. I have been looking for glue that would be pasty and dries quickly.
JB Weld is too hard for general use. I have always needed something
When I say "paste", I mean thick as toothpaste, one can easily spread
thin enough and dries quickly. I have some projects at hand I need
something like that.
Thanks.
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
liquid nails.
PL Premium construction adhesive.
Goop.
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
I've used this DAP contact cement with success. Use a small brush to cover both pieces, clamp well, wipe off excess with wet sponge. Let set for 24 hours. Before you start, make sure all old glue is removed from the panels.
I spent more $ on the right clamps then on the cement. Others have posted in these forums.
Good luck.
DAP Contact Cement
DAP Contact Cement
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Oka wrote: 21 Aug 2021, 00:26 DoorPanel01.JPG
Thanks.
I glued all 4 panels of my 03 S80 T6. There is no good quick way to do this. I had to use clamps and gallons of liquid to press everything together while it dried. If I were to do it again I would give the Surebond a try. Worked excellent in the engine compartment. Use on the flat surfaces and then a large bead around the edges. Hard rubber feel after it dries and won't come apart with heat. Just use 96% alcohol on the mating surfaces to rid of dust and grease if any.
https://www.amazon.com/High-Temp-Silico ... 330&sr=8-2
Check out the last video and see the part I had to glue together. The guy only seal the circular port whereas I glue the entire bottom back on and the air box is right above the exhaust manifold.
viewtopic.php?f=25&t=98015
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Contact cement will work well for this task. I tried several things, but contact cement works. It it not a fast job.
Clean the old surface of glue by scraping. Apply the contact cement to both surfaces where you can and let it harden. Plan to use small strips of boards to spread the clamping load on the exposed side of the panel. This will prevent marking the panel. When you have your clamping plan ready, use acetone to reactivate the contact cement and then assemble and clamp quickly. Work in a well ventilated area (outdoors). Both the acetone and contact cement are bad to inhale.
MoVolvos
Post by MoVolvos »
volvolugnut wrote: 21 Aug 2021, 09:04
+1
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Oka wrote: 21 Aug 2021, 00:26 2. I have been looking for glue that would be pasty and dries quickly.
Hum ... 3M™ Thermal Bonding Film 583 .. or something like it?
Heat or solvent activation.
Datasheet.
Active
Past
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
from your photo i see you need to pull the two sections apart, as it will come apart later, clean the green off and glue it with proper glue volvo should have used instead of the spray.
ive done all 4 doors I used regular PVC wood glue, make sure you remove the green stuff. i used a dremel. need to weigh it down and allow to dry for 24hours I tried pulling them apart and its rock solid.
TIP check that no glue has run onto good side before it dries.
MoVolvos
Post by MoVolvos »
darylrobert wrote: 22 Aug 2021, 04:10 from your photo i see you need to pull the two sections apart, as it will come apart later, clean the green off and glue it with proper glue volvo should have used instead of the spray.
PVC wood?
Glue? Brand or a picture of glue used.
The original Green Glue. If a Dremel is required it means it's really stuck on there so no need to removed it. The pressure/press fiber used to make the door carcass will be compromised and dusty if you remove the top surface.
As with all 4 panels on our 03 S80 T6 it was not necessary to remove the old glue as the roughness provides a good mechanical bond between the two surface. Just clean with 96% alcohol as moisture from the 70% alcohol is not a friend to bonding.
If you can cleanly peel the original glue then you must removed it otherwise don't create unnecessary and or potentially compromising work unless the particular glue you used is superior to anything out there.
darylrobert
the brand i used is Selleys but i think its a local product. anyone familiar with wood glues knows PVC dries hard and will stick to anything. it can be messy and takes 24hrs to set so may not suit the "pasty dry quick glue" but all good strong glues take time set.
As an extra step i also painted some clear lacquer on the board to protect it from moisture.
