HI Folks
Greetings from NZ
I found a 264GL B27E summer 2017 and started a slow process of restoring it when I get time. Its a stop start progress and looking for advices and tips. Some pic below.
Greetings from NZ - 1977 264GL Barn Find project
- volvo264
- Year and Model: 1977 264 GL B27E
- Been thanked: 3 times
Thanks . i am trying to restore any parts that is salvageable and documenting as I go . So far panels are in good shape and engine is good pretty condition 234,000 km. These k-jet do not like sitting idle ... It was in a barn for 17 years . Some of the Upholstery faded but not too damaged. Definitely going to install new underlay and vibration/soundproofing layer. More pic below
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Fish oil...huh! I've never seen that before. Does it all wash off with soap and water and do you degrease it?
- volvo264
Its something we do a here in NZ and Australia.. Its does protects the sheet , penetrates well and prevents rust forming. These Fish oils are deodorised, long lasting, rust inhibiting coating . You can get them in local auto shops over here .BlackBart wrote: 26 Aug 2021, 12:02 Fish oil...huh! I've never seen that before. Does it all wash off with soap and water and do you degrease it?
https://www.repco.co.nz/en/car-care-pan ... p/A1221672
On the steel panels, this is the process I use
On panel cavities you can apply the fish oil or ATF33 ( RED/PINK mineral AT Fluid) to keep moisture out etc... ATF33 is for the BW35/55 gearbox & power steering fluid (ATF TYPE G)
These are old school method, time consuming but I am not in a hurry. I have seen may poorly restored car panels start rusting after 2-3 years.
For underbody , the car already had a good Bituman rubbery coating, but i water blasted, air dried and applied another fresh coat . These steps should give a good seal underbody and for the panel before painting from rusting.
- 774 Views
Last post by Mr. Weekend
- 20 Replies
- 3259 Views
Last post by j-dawg
- 1409 Views
Last post by Marauder 1
- 10 Replies
- 2762 Views
- 52 Replies
- 7064 Views
Last post by vtl
