P0121
Lanrow
Year and Model: 2001 v70
Post by Lanrow »
P0121 still coming in fault code. I have replaced the foot pedal and even from Swedish car parts. The car will start and run but is not drivable do to little response when pushing on foot pedal. Have followed etm bulletin from this sight on troubleshooting wiring down to etm. I have system voltage on the green wire downstream of connector going to etm. Any help would be greatly appreciated.
Has thanked: 2203 times
Been thanked: 1852 times
Have you tried speaking the Xemodex? They repair the ETM unit using contactless position sensors. But they can I believe help you to figure out if the ETM is the issue or something else. ETM's are an issue on 99-02 Volvos using the Magetti Marrelli (?) units.
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
scot850 wrote: 25 Aug 2021, 16:03 Mageti Marrelli.
Don't mention the Italian Curse by it's name, Neil, or it might come upon you!
Other than that I have nothing productive to add. Sorry, OP.
But if you have a 99 to 02 car, the ETM is a very likely culprit.
1996 855 R,
2010 V70 D5,
