Many of us suffer the annoying loose tailgate trim on our V70's. When you close the hatch, the trim unattaches itself and jiggles about. It rattles when driving and when you open your hatch, it hangs down and just generally looks janky. I know it's a big problem because there are kits available to fix the cracked plastic mountings that lead to this issue. However, what if the plastic is in such bad shape that there's nothing to screw the repair kit into? Well, I have a fix.
The issue is that you have to rebuild your mounting point. You need something that the screws from the repair kit can bite into. I choose to use some scrap hardwood. I think it was maple.
First we need to make a piece of wood that'll nestle nicely into the space. I used some cardboard to get the shape.
You can see her that the tan plastic on top is completely gone. There's nothing to attach the repair kit screws.
Next you cut the wood and test fit it.
I used 5 minute epoxy and a clamp and allowed everything to set. You should pre-drill the holes for the screw so you won't crack the hardwood later when you fasten the steel bracket with the screws.
Here's the complete repair after the repair kit bits are mounted and screwed in. Don't worry that the wood covers part of the hole for the retainer. It turns out there's plenty of wiggle room to slide the retainer clip through.
So there you have it. My tailgate trim is nice and tight and I think this will last for quite a while.
Tailgate trim loose and falling down? A more reliable fix.
songzunhuang
- Year and Model: 98 V70 T5
- Has thanked: 2 times
- Been thanked: 30 times
Song Huang
1998 V70 T5 - Hurt your eyes red
2000 Honda S2000 - Berlina Black
1984 BMW 633CSi - Dolphin Grey
2024 Lexus - Eminent White Pearl
2004 XC90 T6 AWD Ruby red (RIP)
- RickHaleParker
- Been thanked: 980 times
I smell a project for somebody wanting to play with his 3D printer ... Its not me I don't have a 3D printer.
A repair kit could be made out of a solid piece of wood and a little sheet metal for a cap.
Active
Past
Past
- Has thanked: 2207 times
Nice fix and you have answered a question I had a long time ago when hit with this issue and wondering what to do if the plastic was that bad! Thanks for sharing.
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
5 minute epoxy has never really held up very long for me, though I love the idea of five minute epoxy. I hope it works better for you!
songzunhuang
You know, you may be right. We'll see how it does and I'll report back if it fails.850oldschool wrote: 25 Aug 2021, 17:03 5 minute epoxy has never really held up very long for me, though I love the idea of five minute epoxy. I hope it works better for you!
Song Huang
- RickHaleParker
What are you doing to prep the bonding surfaces?850oldschool wrote: 25 Aug 2021, 17:03 5 minute epoxy has never really held up very long for me, though I love the idea of five minute epoxy. I hope it works better for you!
Active
Past
Past
850oldschool
Nothing special, but they were freshly cut wood and plastics that I was using to make jigs and fixtures. I came to the conclusion that the long curing time of regular JB weld was worth waiting for. Heat really speeds it up, though. Probably two hours in a closed car in full sun.RickHaleParker wrote: 25 Aug 2021, 20:05What are you doing to prep the bonding surfaces?850oldschool wrote: 25 Aug 2021, 17:03 5 minute epoxy has never really held up very long for me, though I love the idea of five minute epoxy. I hope it works better for you!
- RickHaleParker
It might be oil film on the plastic. Light sand then wipe with a cloth damp, not wet, with Acetone. The light sand will produce a surface the epoxy can grab a hold of. The Acetone will remove any oils or microscopic particles.850oldschool wrote: 26 Aug 2021, 10:45 Nothing special, but they were freshly cut wood and plastics that I was using to make jigs and fixtures.
Active
Past
Past
- Has thanked: 1611 times
- Been thanked: 4071 times
There is a world of difference in work ability and strength of “ regular epoxy “ and five minute epoxy. You get a better pot and holding strength with regular. A repair like this can easily sit overnight without loss of use of the car
