Engine skips after timing belt replacement Topic is solved
wool
- Year and Model: 2007 s40
I was in the midst of replacing the timing belt on my 2004 XC70. I've replaced belts several times without incident. Unfortunately, the crank pulley would not budge. I set the timing marks, locked the cams then sent the car to a shop to remove the crank pulley and replace the timing belt. The next day I get a call to come to the shop because the crank would not turn. As it turned out I was able to turn the crank a full 360 degrees. I realized he was trying to turn the crank while in a compression stroke. He rotated the crank several times, replaced the belt, and removed the cam locks. He had problems starting the car. Once it was running he did a road test and found that the engine was "skipping" until it was at a higher RPM. Any thoughts?
Do a compression test to rule out valve damage.
Can you describe what “ skipping “ means?
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
you dont actually have to remove the crank pulley to change the belt, i just remove the plastic bottom cover and slide the belt in
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
Maybe an ignition coil that's bad? That feels like "skipping" I guess. If they are old, just pulling them off the plugs might cause them to break.
BMW 540i 2002
S70 Base 2000
- 426 Views
Last post by mainemofo
- 1901 Views
Last post by RickHaleParker
- 23 Replies
- 17134 Views
Last post by jonesg
- 20 Replies
- 17401 Views
Last post by Hurtfeelings
- 5251 Views
Last post by jimmy57
