Thank you, vtl. You are very talented!
So called CEM-B is about to become a historical artefact. If vtl or somebody else could hack the P3 cem, it would be fantastic. I am ready to donate, support etc. I have some P3 dumps if interested.
Thanks
Vida CEM swapping
- RickHaleParker
- Been thanked: 980 times
That changed October 28, 2016. Upheld in the 2018 DMCA Exemptions.vtl wrote: 28 Aug 2021, 15:57 It is just illegal or stinks very much like it is illegal in US under DMCA law
2015 DMCA Exemptions.
1. Motion pictures (including television shows and videos)
2. Literary works, distributed electronically, protected by TPM interfering with assistive technologies
3. Computer programs that enable devices to connect to a wireless network (“unlocking”)
4. Computer programs on smartphones and all-purpose mobile computing devices (“jailbreaking”)
5. Computer programs on smart TVs (“jailbreaking”)
6. Vehicle software to enable diagnosis, repair, or modification.
7. Computer programs to enable good faith research of security flaws
8. Video games requiring server communication
9. Software to limit feedstock of 3D printers
10 Patient data from implanted networked medical devices
"Computer programs that control
the functioning of motorized land
vehicles.
37 CFR §201.40(b)(6)
Details: Where circumvention is a necessary step undertaken by the authorized owner of a vehicle to
allow diagnosis repair, or lawful modification of a vehicle function and where circumvention does not
constitute a violation of applicable law, including regulations promulgated by the U.S. DOT or EPA.
Circumvention may occur no earlier than October 28, 2016. "
( No screwing around with safety ( DOT ) and environmental protection (EPA ).
This exemption does not cover computer programs primarily designed for control of telematics or
entertainment systems for vehicles. ( No hacking services such as Satellite radio and vehicle tracking )
Active
Past
Past
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Good to know that our lawmakers are less insane than they were before October 28, 2015.
Anyways, I don't own "rights" for that known P3 CEM pin finding algo. Also the P3 cracker would make more sense in existing as a standalone software for DiCE, which virtually every DIY Volvo owner has. Means, it probably should be written for Windows, which means I'm out =)
- RickHaleParker
It is out of the hands of the lawmakers. The Copyright Office makes the rules from now on. Bureaucrats don't need to appease political donors because they are not elected. Bureaucrats don't make changes all willy-nilly because rule change is a labor intense process. Once a CFR ( Code of Federal Regulations ) is changed, the change is pretty stable.vtl wrote: 28 Aug 2021, 21:27 Good to know that our lawmakers are less insane than they were before October 28, 2015.
The whole idea of a regulatory agency is to bring about sanity because it is impossible to legislate for every consistency.
Active
Past
Past
Hi
maybe its stupid question but i cant get it running right. Its my first time with arduino and C++ so please dont be hard on me
I managed finally to load everything to teensy and got it wired up. When trying on car everything starts and it detects CEM PN but from there it won't actually do anything.. all i get is messages like this:
and at the end it says:
I would be very thankful if anyone could please teach to stupid(me) what i did/do wrong
Code: Select all
Part Number: 30728542
Searching P/N 30728542 in 49 known CEMs
CAN HS baud rate: 500000
PIN shuffle order: 3 1 5 0 2 4
Putting all ECUs into programming mode.
CAN_HS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
Initialization done.
Calculating bytes 0-2
1000 pins in 639 ms, 1564 pins/s, average response: 0 us, histogram 0 to 0 us
us:
[ 00 -- -- -- -- -- ]: : latency 0; std nan
[ 01 -- -- -- -- -- ]: : latency 0; std nan
[ 02 -- -- -- -- -- ]: : latency 0; std nan
[ 03 -- -- -- -- -- ]: : latency 0; std nan
[ 04 -- -- -- -- -- ]: : latency 0; std nan
Code: Select all
[ 98 -- -- -- -- -- ]: : latency 0; std nan
[ 99 -- -- -- -- -- ]: : latency 0; std nan
best candidates ordered by latency:
0: 99 lat = 0
1: 01 lat = 0
2: 02 lat = 0
3: 03 lat = 0
4: 04 lat = 0
95: 95 lat = 0
96: 96 lat = 0
97: 97 lat = 0
98: 98 lat = 0
99: 00 lat = 0
best candidates ordered by std:
0: 00 std = nan
1: 01 std = nan
2: 02 std = nan
3: 03 std = nan
4: 04 std = nan
95: 95 std = nan
96: 96 std = nan
97: 97 std = nan
98: 98 std = nan
99: 99 std = nan
lat_k 0-1 nan%, lat_k 98-99 nan%, lat_k 0-99 nan%
std_k 0-1 nan%, std_k 98-99 nan%, std_k 0-99 nan%
pin[0] choose candidate: 99 (latency only)
Code: Select all
CPU Maximum Frequency: 600000000
CPU Frequency: 600000000
Execution Rate: 600 cycles/us
PIN bytes to measure: 3
Number of samples: 100
CAN low-speed init done.
Reading part number from ECU 0x40 on CAN_LS
CAN_LS ---> ID=000ffffe data=cb 40 b9 f0 00 00 00 00
CAN_LS <--- ID=00c00402 data=83 10 00 00 00 00 00 04
CAN_LS <--- ID=01e0162a data=40 00 00 08 17 00 1d 00
CAN_LS <--- ID=03600008 data=00 00 00 24 40 09 43 00
CAN_LS <--- ID=0381526c data=00 01 05 3c 07 ff 28 25
CAN_LS <--- ID=012173be data=00 01 00 06 00 02 00 00
CAN_LS <--- ID=01601422 data=00 00 00 01 34 90 06 37
CAN_LS <--- ID=00217ffc data=01 4b 00 10 c0 00 00 00
CAN_LS <--- ID=0131726c data=00 0c 32 00 a0 00 00 3f
CAN_LS <--- ID=014034a2 data=00 5b 00 04 89 00 04 00
CAN_LS <--- ID=03a04004 data=00 a0 ff ff ff ff ff ff
CAN_LS <--- ID=03000042 data=00 00 01 e0 1c 00 02 37
CAN_LS <--- ID=00e01000 data=03 60 00 00 00 00 4c 00
CAN_LS <--- ID=02202262 data=00 00 00 00 50 00 40 00
CAN_LS <--- ID=02c1302a data=00 04 00 b4 13 08 80 00
CAN_LS <--- ID=00217ffc data=03 4b 00 10 c0 00 00 00
CAN_LS <--- ID=01e0162a data=80 00 00 00 17 00 9d 00
CAN_LS <--- ID=0131726c data=80 0c 32 00 a0 00 00 3f
CAN_LS <--- ID=00c00402 data=c3 10 00 00 00 00 00 04
CAN_LS <--- ID=03c01428 data=80 80 00 00 0e 37 00 00
CAN_LS <--- ID=02300492 data=00 00 00 00 00 00 00 04
CAN_LS <--- ID=012173be data=40 11 00 06 00 82 00 00
CAN_LS <--- ID=02006428 data=01 00 00 00 00 00 00 00
CAN_LS <--- ID=02616cfc data=00 40 00 00 00 50 00 00
CAN_LS <--- ID=02803008 data=49 04 00 00 00 00 20 00
CAN_LS <--- ID=01e0162a data=c0 00 00 00 17 00 5d 00
CAN_LS <--- ID=01017ffc data=12 04 02 02 05 02 05 01
CAN_LS <--- ID=00c00402 data=03 00 00 00 00 00 00 04
CAN_LS <--- ID=03200408 data=01 18 10 00 00 00 00 00
CAN_LS <--- ID=04000002 data=00 00 00 04 06 06 d4 4b
CAN_LS <--- ID=012173be data=80 01 00 06 00 02 00 00
CAN_LS <--- ID=02c1302a data=40 04 00 b4 13 08 80 00
CAN_LS <--- ID=01e0162a data=00 00 00 00 17 00 9d 00
CAN_LS <--- ID=00c00402 data=43 10 00 00 00 00 00 04
CAN_LS <--- ID=02803008 data=89 04 00 00 00 00 20 00
CAN_LS <--- ID=01e0162a data=40 00 00 00 17 00 1d 00
CAN_LS <--- ID=012173be data=c0 11 00 06 00 82 00 00
CAN_LS <--- ID=03e0004a data=00 00 00 00 1d e0 40 00
CAN_LS <--- ID=02c1302a data=80 00 00 b4 13 08 80 00
CAN_LS <--- ID=0131726c data=00 0c 30 00 a0 00 00 3f
CAN_LS <--- ID=04200002 data=00 00 3c 00 5a 37 4e 00
CAN_LS <--- ID=01e0162a data=80 00 00 08 17 00 5d 00
CAN_LS <--- ID=02616cfc data=00 44 00 00 00 50 00 00
CAN_LS <--- ID=02803008 data=cb 04 00 00 00 00 20 00
CAN_LS <--- ID=02202262 data=00 00 04 00 50 00 40 00
CAN_LS <--- ID=01e0162a data=c0 00 00 00 17 00 9d 00
CAN_LS <--- ID=03a04004 data=00 b0 ff ff ff ff ff ff
CAN_LS <--- ID=02c1302a data=c0 04 00 b4 13 08 80 00
CAN_LS <--- ID=02803008 data=09 04 00 00 00 00 20 00
CAN_LS <--- ID=00c00402 data=03 10 00 00 00 00 00 04
CAN_LS <--- ID=0131726c data=80 0c 30 00 a0 00 00 3f
CAN_LS <--- ID=01e0162a data=00 00 00 00 17 00 1d 00
CAN_LS <--- ID=03c01428 data=c0 80 50 00 0e 37 00 00
CAN_LS <--- ID=01e0162a data=40 00 00 00 17 00 5d 00
CAN_LS <--- ID=00c00402 data=43 00 00 00 00 00 00 04
CAN_LS <--- ID=012173be data=c0 01 00 06 00 02 00 00
CAN_LS <--- ID=01017ffc data=17 01 01 02 01 03 02 01
CAN_LS <--- ID=03600008 data=00 00 00 04 40 09 43 00
CAN_LS <--- ID=012173be data=00 11 00 06 00 82 00 00
CAN_LS <--- ID=01e0162a data=00 00 00 08 17 00 1d 00
CAN_LS <--- ID=012173be data=40 01 00 06 00 02 00 00
CAN_LS <--- ID=01e0162a data=40 00 00 00 17 00 9d 00
CAN_LS <--- ID=01e0162a data=81 00 00 00 17 00 5d 00
CAN_LS <--- ID=012173be data=80 11 00 06 00 82 00 00
CAN_LS <--- ID=00c00402 data=83 00 00 00 00 00 00 04
CAN_LS <--- ID=01e0162a data=c0 00 00 00 17 00 1d 00
CAN_LS <--- ID=03c01428 data=00 00 40 00 0e 37 00 00
Can't find part number on CAN-LS, trying CAN-HS at 500 Kbps
CAN high-speed init done.
Reading part number from ECU 0x50 on CAN_HS
CAN_HS ---> ID=000ffffe data=cb 50 b9 f0 00 00 00 00
CAN_HS <--- ID=0042406c data=00 aa 00 00 60 00 00 00
CAN_HS <--- ID=01000020 data=00 00 00 01 e0 04 c0 00
CAN_HS <--- ID=11100024 data=00 00 00 10 7e 37 80 00
CAN_HS <--- ID=01200003 data=8f 50 f9 f0 00 30 72 85
CAN_HS <--- ID=0042406c data=40 88 00 00 60 00 00 00
CAN_HS <--- ID=10400020 data=40 28 40 60 00 00 0e 37
CAN_HS <--- ID=11220028 data=01 00 00 3c 00 00 28 25
CAN_HS <--- ID=0042406c data=80 a8 40 00 60 00 00 00
CAN_HS <--- ID=01200003 data=09 42 20 20 41 30 68 20
- RickHaleParker
Latency detect jumper missing?naxitrall wrote: 01 Sep 2021, 16:36 Calculating bytes 0-2
When was the last time you downloaded the electronics schematics?
Active
Past
Past
- 10034 Views
Last post by RickHaleParker
- 10496 Views
- 27 Replies
- 32096 Views
Last post by cn90
- 10 Replies
- 12378 Views
Last post by jonesg
- 7285 Views
