Vida CEM swapping
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
RickHaleParker wrote: 02 Sep 2021, 10:20 Latency detect jumper missing?
Left unconnected it would be pulled down, always reporting logical 0, CAN message receive timing out after 1 second. In his case it seems it always report 1, which means either a connection to wrong signal or burnt IO pin maybe?
naxitrall
Year and Model: 2001 C70
Post by naxitrall »
I bought https://www.skpang.co.uk/products/teens ... ceae&_ss=r
And follewed can wires from schematics that was in github page..
vtl
Post by vtl »
Check your wiring once again. If all looks good, you may have burnt the line in chip. Move pin 4 to other digital IO pin and reflect it in the code: https://github.com/vtl/volvo-cem-cracke ... er.ino#L35
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
vtl wrote: 02 Sep 2021, 10:30 In his case it seems it always report 1, which means either a connection to wrong signal or burnt IO pin maybe?
The Teensy 3.3V line is right next to CRX1 ...... one pin position off perhaps. That would tie Latency detect high.
Active
Past
RickHaleParker
naxitrall wrote: 02 Sep 2021, 10:37 And follewed can wires from schematics that was in github page..
One of the early schematics had a omission in it.
Post the one you used so we can check it or download the latest and compare it to what you used.
Active
Past
swinokur
Year and Model: 2013 C30 Polestar
Has thanked: 2 times
Post by swinokur »
Hi there,
I've just gotten back from my first attempt to crack the CEM on my 2013 C30, sadly I didn't succeed on my first two tries!
I'm hoping someone here has some suggestions on what to do next:
- I built the hardware based on the schematic just downloaded from: https://raw.githubusercontent.com/vtl/v ... ematic.png
-- I used two "waveshare" canbus transceiver boards:
https://www.waveshare.com/sn65hvd230-can-board.htm
https://www.waveshare.com/w/upload/c/c5 ... ematic.pdf
-- and an OBDII cable from amazon. (Yep, I checked that I had the right pins using a meter)
- To power the teensy I used a powered USB hub between the laptop and the device: https://www.newark.com/cypress-semicond ... dp/19M6485 (yep, exactly this object)
-This was done in the car, with a battery tender attached to the car.
- As seems to be indicated, I connected the Teensy and turned the ignition to P2 within a couple seconds of attaching the Teensy to power.
I tried a run with all of the defaults, using the build from July 20th that is on github.
After that first run was not successful, based on some of the reading in this thread I un-commented line 1031 (// set_arm_clock (180000000);) and tried again.
This was also not successful.
I've attached logs of both runs.
Let me know if there's more information to provide - and what other tricks folks have done to get this to pop?
thanks!
TyCommander-9903900-Teensy-180Mhz-Run 2.txt
(56.11 KiB) Downloaded 99 times
TyCommander-9903900-Teensy-600Mhz-Run 1.txt
(55.64 KiB) Downloaded 108 times
5ft24
Year and Model: 2005 XC90 V8 AWD
Has thanked: 20 times
Been thanked: 12 times
Post by 5ft24 »
Is the 2013 C30 a P3?
swinokur
Post by swinokur »
5ft24 wrote: 05 Sep 2021, 16:44 Is the 2013 C30 a P3?
I think all C30s are P1?
Based on the part number reported by the software (31327215) it would be this part https://www.volvopartswebstore.com/prod ... 27215.html -- which appears to be the same ECU as all the rest.
swinokur
Post by swinokur »
After reading more of this thread, I found the strong suggestion to not power the teensy with USB power and switched over to a buck transformer that I had in a parts bin: https://en.cosel.co.jp/product/powersup ... /SUS61205/ (5v 1.2A output, 12V input). I connected it to the OBD II pins 16 and 4. (I wasn't sure if pin 4 or pin 5 was more appropriate or mattered, but one other design I saw in the thread used Pin 4, so that's what I settled on.)
Then I tried some more runs.
Run 3 was done with the default settings.
Run 4 was done with Samples = 30, 180Mhz clock, and LAT_ONLY commented out.
Then I read some more in this thread, and saw that some people called for the removal of the terminating resistors on the CAN transceivers. I removed those resistors and tried again.
Run 5 was the same settings as Run 4. (Samples = 30, 180Mhz clock, and LAT_ONLY commented out)
Run 6 was was back to 600Mhz, with Samples = 30 and LAT_ONLY back to default.
At this point I'm imagining that my CAN bus transceivers might be to blame, being the 'inexpensive' amazon/china type.
I suppose it could also be my wiring - between the teensy and the transceivers they're 4" breadboard .100 pin female to female connection wires.
(I'm fairly adept at soldering, if it is just easier to pull the silly thing out of the car and pull the data off the chips with a programmer or adapter, let me know if there's a guide to that somewhere.)
thanks!
TyCommander-9903900-Teensy-180Mhz-Run4-Samples30-Lin-Buck.txt
(65.11 KiB) Downloaded 90 times
TyCommander-9903900-Teensy-600Mhz-Run3-Buck.txt
(66.15 KiB) Downloaded 101 times
TyCommander-9903900-Teensy-600mhz-Run6-S30-buck-no120.txt
(67.76 KiB) Downloaded 98 times
TyCommander-9903900-Teensy-180mhz-Run5-S30-Lin-buck-no120.txt
(55.74 KiB) Downloaded 86 times
RickHaleParker
All C30s are P1. However there been clues that later P1s have a different shuffle order.
PIN shuffle order: 0 1 2 3 4 5 works on some P1s.
VTL has more the one shuffle order in the code but I am not sure if he has more then one shuffle order for the P1. I think he was looking for a cutoff point at one time but never found one.
Active
Past
