This seems like a really bad way to DIY alignment
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Two accuracy failure points: the contraptions' straightness and the car's bumpers' straightness.
Manual Alignment.jpg (143.71 KiB) Viewed 922 times
Manual Alignment2.jpg (206.81 KiB) Viewed 922 times
Also -> Amazon link
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
It's alright, this is how it was done for decades, right? Some trigonometry formulas, and the method even works with non-parallel strings. Just measure everything as best as you can.
I did a spreadsheet with those forumlas a few year back, it worked fine for my AWD P2 unless the subframes were misaligned (which was the case with mine). The process is very tedious as it requires to setup and remeasure everything after a failed test-drive, so at the end I started to align the thrust vector be feel in many small adjustments and finally toe-in on both axles. Car never pulls anywhere, tire wear is even.
Of course that DIY alignment was a fallback after multiple incorrect (and expensive, hello Boston) shop alignments. I wish I've had their equipment in my garage...
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
matthew1 wrote: 02 Sep 2021, 12:28 Two accuracy failure points: the contraptions' straightness and the car's bumpers' straightness.
Exactly, I never trusted that stuff. It's ok to get it rolling straight enough to get it to a good alignment shop. I'm happy to pay the 80 bucks.
vtl
Post by vtl »
BlackBart wrote: 02 Sep 2021, 13:47 Exactly, I never trusted that stuff. It's ok to get it rolling straight enough to get it to a good alignment shop. I'm happy to pay the 80 bucks.
$80? Locals take $125, dealer was $170 a few years back. Nobody did it right.
BlackBart
Post by BlackBart »
I think that's a basic front end at my neighborhood tire shop. They have an old school guy who just does alignments.
But yes, I've had issues with them as well - couple of trips back to discuss the numbers on his printout.
matthew1
Site Admin
Post by matthew1 »
I'd look to anchor those parallel lines off something besides the bumper. It just seems like that would be one of the last pieces of a car I'd expect to be a plum 90°, especially on something 15+ years old... or 35 years old like in the pictured example.
P2 cars' front bumper covers are always suspect because they catch on parking blocks and pull off a bit.
Also -> Amazon link
vtl
Post by vtl »
The guy had to center it by measuring the distance from wheel hubs/caps before he even pretended he's doing alignment. This is written in instructions to any alignment rack of such design/principle.
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
I've done multiple string alignments but only on 2WD vehicles. String was attached on jack stands. Nothing on the vehicles. You have to find the full span of the axles from right to left.
