08 3.2 FWD driveshafts: can I replace just the CV joint?
ogatrulle
Year and Model: xc90 2008
Been thanked: 10 times
Post by ogatrulle »
08 3.2 FWD XC90
I'm starting to hear telltale ticking at low speed when the steering wheel is at the left steering stop, so I have some driveshaft work in my future.
It looks like brand V complete driveshafts are in the $600-$700 range. But I didn't see any a la carte CV joints. Is there a mechanical reason not to just swap the CV joint(s) (maybe the driveshaft is balanced as an assembly?)
Or does "everyone" just swap in a new complete driveshaft?
2006 v70 2.5T; 2008 xc90 3.2
Capndirk
Year and Model: 2009 XC90
Has thanked: 13 times
Been thanked: 14 times
Post by Capndirk »
I replaced my front (FWD) axles pre-emptively at 90K with a DSS right and a Cardone left. Put about 20k on them and all is well.
ogatrulle
Post by ogatrulle »
That's a good data point. I don't know what to think about aftermarket driveshafts, but they sure are less expensive than brand V.
Been thanked: 504 times
Post by cn90 »
- How many miles in your 08 3.2?
- If the rubber boot is not torn, you can reboot it using GKN boot, about $18 at FCPEuro.
That is for OUTER boot. You may have to find INNER boot elsewhere.
Sometimes, new grease takes care of the noise.
- Did you get underneath and look at the rubber boots for leak?
ogatrulle
Post by ogatrulle »
160k miles. Boots are OK. I think it's just wear in the outer joint.
The last 30k miles were put on by teenaged son, however, so it's possible there has been some, ah, "abuse."
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
ogatrulle wrote: 05 Sep 2021, 20:53 160k miles. Boots are OK. I think it's just wear in the outer joint.
I replaced the front pair with Volvo/GKN. Here is a pix of OE axle at 155,000 miles.
