Nice work! Which capacitors do they require?Chuck W wrote: 05 Sep 2021, 21:41 Just finished replacing the capacitors in a handful of junkyard spare fuel pump relays I have.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
- Has thanked: 1611 times
- Been thanked: 4075 times
Best solution to 14 year old arthritis dog on ferry, with multiple stair cases and broken elevator….
Six foot , 180 pound dense muscle college athlete…..
Swapping stuff for her house and giving her a free tank of gas…tight budget.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
There is a 22uF and a 100uF capacitor that usually require replacing. (Digi-Key 565-1304-ND and UVY1E101MDD-ND, respectively).
Most were probably "good", but I'd actually forgotten that I had this many. I had no idea on the fitness of them all, so I figured it wouldn't hurt to just do the lot of them. Marked each with a date, so I know their status now.
I’ve ordered 100 PCs each of these, the latter are on extended back order but hopefully will arrive soonChuck W wrote: 06 Sep 2021, 06:08There is a 22uF and a 100uF capacitor that usually require replacing. (Digi-Key 565-1304-ND and UVY1E101MDD-ND, respectively).
Most were probably "good", but I'd actually forgotten that I had this many. I had no idea on the fitness of them all, so I figured it wouldn't hurt to just do the lot of them. Marked each with a date, so I know their status now.![]()
Mvs people can pm me amd I’ll put some in us Mail.
- Chuck W
I bought enough for 10 repairs when I bought my last batch.
Had a few spare moments yesterday morning, I decided to swap out the fuel pump in the wife's '97 GLT (still chasing down misfire codes, and it's looking more like a fuel issue). I had a lightly-used Walbro pump in my stash from a previous car, so I grabbed that and stuck it in there.
No idea how old this pump is, but was within spec in the driveway when testing (didn't have long enough hoses to put it out where I can see it while driving).
My handy tool used to remove the fuel lines, made from an old Ford accessory bracket I had in the garage.
The test drive showed decent results, but we'll see if the CEL stays away.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Dug another piece out of long term storage, helps scratch the itch to get the Duett needle off the aught peg.
Paint or patina ? Gotta think about it once it gets a scrub.
- Has thanked: 317 times
- Been thanked: 531 times
That's a pretty cool piece!
- foggydogg
"Emergency" gas tank, fits inside the spare tire. Came in a box of spares with the 122.
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
fixed my AC by jamming the connections with a home depot reciept. turns out it was loose connections causing intermittent operation of my MCC. Will eventually resolder all the connections for a permanent fix
2008 S60 2.5T Auto (Sold)
