Hello Forum!
Wanted to say "HI" to the group...just drove a 98 V70 AWD up from Marco IL FL to Chicago IL over the weekend and am getting to know the car.
The Skinny:
71K Miles (not a typo)
Nautic Blue/Tan
1 Owner, all service records (And the Monroney Sticker!) - Tons of work done exactly when it was needed...probably could use a torque tube bushing...
Lived in FL all it's life, garaged in A/C (paint, seals and interior are incredible)
Will be the "other car" for winter/errands/etc.
Looking to add rails/rack, wood wheel (XC SE), GROM BT...just slight upgrades and tighten it up a little. Have some 1998 V70R wheels I will probably refurbish and slap on there...some jewel headlights... Looking forward to learning more about these great cars. We had a 2000 V70 SE years ago and really liked it, so back into the fray...
Thanks all,
John
Hello All! New owner of a 1998 Nautic Blue V70 AWD...
- Has thanked: 2856 times
- Been thanked: 1332 times
This has got to be a typo.
Oh wait...
Welcome and thanks for joining. Wonderful V70 you have there. So pretty.
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Very nice! Rare to find gems like this at the low miles.
Double check all the rubber hoses and related things, because sometimes age will do damage, even with the low miles. I'd do a couple transmission fluid drain/fills, and if your AWD system is still functional (should be at that mileage), have the bevel (angle) gear fluid changed.
Hope you get many years and miles out of it!
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Has thanked: 2199 times
Welcome and what a beautiful car. Condition is amazing!
There are several issues with the AWD system and if you are getting any clunks or knocks we can enlighten you where to look.
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 112 times
- Been thanked: 17 times
Nice!!!!!!
Nautic Blue
Is a special Hue
It’s cool for school
And all the other kids drool
Is a special Hue
JHop
- Year and Model: 1998 V70 AWD
- Been thanked: 3 times
Hi Neil! Thanks! The “thud” happened mainly when backing off and also when hitting the acceleration on the highway…with cruise on and without. Around town I don’t think I feel it. It almost feels like a highway expansion joint, which originally for the first part of the trip I thought it was, then I started paying more attention. So, yes any guidance would be great. Once I rearrange the garage a bit I’ll get it up on the lift and start to check it out.scot850 wrote: 10 Sep 2021, 16:02 Welcome and what a beautiful car. Condition is amazing!
John
1998 V70 AWD
2015 911 Carrera
2013 MB GL450
1968 GTO Convertible
2015 911 Carrera
2013 MB GL450
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Way too pretty for a winter ride! Amazing find, enjoy it.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
The 4 places were a clunk can happen are:
1) Engine mounts: Check top and bottom torque mounts as the bushes fail. Note the lower is NLA. IPD does a poly-bush
replacement. Also check the RH engine mount/pad under the crank pulley for separation.
2) Prop-shaft: Check the front joint (fails due to proximity to catalyser), center support mount bush. Not easily replaced. Colcorado
Driveshaft are the goto on this.
3) Viscous Coupling: Check the casing mount at the front of it under the RHR passenger floor. It fails and causes a clunk.
- 36 Replies
- 9861 Views
Last post by erikv11
- 13 Replies
- 4099 Views
Last post by bmdubya1198
- 1428 Views
Last post by Jeff Schubert
- 963 Views
Last post by Oly850
- 9 Replies
- 1776 Views
Last post by JMW92
