Broken bolt head leads to Broken Extractor Bit
Has thanked: 1614 times
Been thanked: 4078 times
Here is the go-to site for part numbers...you will need your VIN to get the right engine mount number
https://www.volvopartswebstore.com/cars ... parts.html
I’ve got the early 1998 engine mount spare, I think
ericmci
Year and Model: 1999 S70 GLT
Has thanked: 73 times
Been thanked: 15 times
Post by ericmci »
I was able to find the right part for my 99
9180961
I believe the 98 is different. I appreciate the offer!
The new one will be here on Wednesday with new bolts as well.
Time to get this one done!
Has thanked: 2215 times
Been thanked: 1853 times
Glad you were able to find it and you found there was a difference in the years.
Good luck with the removal!
ericmci
Post by ericmci »
I tell you I am not sure how to get at the 11-12mm bolt that sits behind the serpentine belt pulley.
I was able to move the refrigerant pipe out of the way more but there just isn't any space to get a good wrench on it
and the pulley is in the way of a socket.
I am kind of stumped.
Can you remember what you did to get to it?
I can get you a picture of the scene tomorrow.
For now, this is a pict off ebay pointing to it.
I will have to wait until I see a picture as I can't recall. An open wrench or crowfoot cannot get access?
If you take off the lower timing belt cover , which is an M8 bolt with a 10 mm hex head, you should be able to get to that bolt at the front of car, left side of engine
ericmci
Post by ericmci »
I am thinking if I can wiggle the half-moon piece of the timing cover out I can get access with either a slime wrench or crow foot without removing the pulley.
I think that pipe is the fuel pipe so be careful! With the plate removed, do you have a cranked ring wrench as it may be the best option.
Those bolts will be too tight and bound in for anything other than a socket. Get good access even if you have to pull the timing belt and pulley
seggs
Year and Model: '09 S60, 04 XC70
Been thanked: 4 times
Post by seggs »
I had a head break off one of my exhaust manifold bolts. After fighting with it to no avail with extractors, I brought it to a local machine shop. They welded a new bolt on the stump, and along with the welding heat, it then came out easily with a wrench. If you have enough of a stud left to work with, and a friend with a welder, that might do the trick. They literally had it out in 5 min, and preserved the threads.
:mrgreen: Seggs
2009 S60 2.5T FWD 155k
2008 S60 2.5T FWD 150k
2004 XC70, 220k(sold)
2005 XC90 2.5T AWD 173k(sold)
2003 S60 (sold)
