V70 violently jerks
Craigm7
Year and Model: 2006 v70 2.4 d5
Post by Craigm7 »
Bare with me guys new to this.
Whilst driving my 2006 v70 2.4 d5 there was a sudden loud popping air release type noise. Stopped immediately thinking a tyre had blown, which it wasn't. When setting back off it immediately stalled. Tried again slowly, the car won't go past 10mph due to it constantly jerking jumping violently. Car ticks over fine, but when revved it fluctuates up and down. Hard revs produce grey smoke from exhaust and smoke comes from where the swirl actuator link connects to the head.
Any advice will be greatly appreciated.
Regards Craig.
Craigm7
Post by Craigm7 »
Whilst driving my 2006 d5 there was a sudden loud popping air release type noise. Stopped immediately thinking a tyre had blown, which it wasn't. When setting back off it immediately stalled. Tried again slowly, the car won't go past 10mph due to it constantly jerking jumping violently. Car ticks over fine, but when revved it fluctuates up and down. Hard revs produce grey smoke from exhaust and smoke comes from where the swirl actuator link connects to the head.
Regards Craig.
Been thanked: 4068 times
We don’t get the diesels here , Craig but if it’s a turbo car I would guess an induction hose has popped off
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
Do you have a check engine light? ive blown a turbo hose , a piston ring and head gasket. none made the car jerk. sounds like a missfire, got to check what codes your getting.
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Yeah, that sounds a bit like overboost and a hose blowing off. Also check the intercooler case and fittings. (Does a diesel have an intercooler?)
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
As other said, check turbo to OTE (over the engine) pipe, OTE to intercooler, intercooler to intake.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
jerking might be transmission shifting being affected by the boost leak, loud hissing on mine was the boost pipe coupler hose clamp coming loose. That triggered limp mode. soon followed by turbo shaft breaking. Not necessarily in that order.
darylrobert
Manual transmission wont jerk just no power and you would see black smoke, thats why i thought missfire which i think is white smoke?. Sorry dont know much about auto's
vtl
Post by vtl »
That happened recenetly to a diesel Volvo fellow: bolts of one of the fuel injector stripped the threads inside the head. One bolt first, the other remaining bolt didn't leave much longer. The injector flew away, causing wreckage along the way.
