- The video link below shows the guy using Air Hammer, which I don't think is a good idea, too risky IMHO...
You can clearly see the rusty parts in the video.
- BEST is to wait a bit for the PB Blaster to soak in. It may take a week to soak in.
- I assume ROTATE/Tug/Pull?
Dreaded driver side Axle Replacement Tips
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Lift it with your fat chisel, tear the seal with a small angled pick, spray the gap with PB Blaster liberally. Otherwise PB has little chances to get in far enough to reach the C-clip.
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
Guys, sometimes you just got to spend the money to make the job simple.
I got an axle popper and it will go out in seconds with a few good taps.
https://www.amazon.com/ARES-12020-2-Pie ... N1V2&psc=1
vtl
Nah, I have that one, never worked for me, even once.chris11211 wrote: 18 Sep 2021, 17:48 Guys, sometimes you just got to spend the money to make the job simple.
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Chris11211 - I am currently using that exact pickle fork as a paper weight. . Bought it for this axle when I realized it would not pop out using my chisel and pry bar.... and this pickle fork did not work for this particular, extremely difficult) axle either. I will let it soak in PB Blaster for a long while, keep respraying, then go back to this nightmare in a few days. (I also found a new thicker chisel and look forward to introducing it to Mr. Axle.
ALL - Thanks for all the tips and tricks. I will provide an update mid week. I will stay the course working with the fork, chisels, pry bar, prayers, etc until... until extracted (or broken off).
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- Been thanked: 504 times
Someone above said "pick on the seal in situ...", it does not work, there is no space for it.
Below is the link for my DIY, you can see that in contrast to P80 (the 850, S70 series), the P2 trans uses a blind cup, so the end of the axle sits in a blind hole, no exposure to ATF, thus the rust in the rust belt areas.
Here is a pic from that DIY showing the blind hole.
So the idea of PB Blaster for 1-2 weeks should work...
Just spray a bit each day, spray the top of the junction (btw the tripod and the trans)...
DIY: 2004 V70 2.5T Volvo Axle and Seals (110K miles)
viewtopic.php?f=9&t=91594
O.P.,
You may want to tilt the LEFT side up (jack stand or ramp only on the LEFT side) to allow PB Blaster to soak inside the blind hole...
- 2755 Views
Last post by theWIFES_S70
- 731 Views
Last post by jmartin919
- 4343 Views
Last post by ggleavitt
- 21 Replies
- 5003 Views
Last post by jcgirton
- 1853 Views
Last post by E Showell
