Collar sleeve damage
renegade420
Year and Model: 2006 s60r
Been thanked: 3 times
Post by renegade420 »
Looking for a quick opinion. While have a tough time removing the collar sleeve, it was slightly damaged in the process from the grips when pulling it out. Is this damage too significant to try and reinstall and use?
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
It won’t hurt anything, just make sure it slides on and off the bevel gear splines. If it binds, file the collar sleeve splines with a small triangular profile file so it slides on easy, also check the outside machined surface of the colllar and make sure you didn’t scratch it where the seal rides.
2003 XC 70 (sold)
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
My opinion: Clean up the slight damage with a small file. Assure the parts slide together OK. There is not enough damage here to worry about.
renegade420
Thank you both for the replies. I was thinking the same thing but wanted another opinion. The file idea was already floating around in my head. Thanks again!!
Been thanked: 4068 times
Clean it up and use. Smart for checking. Many brains on a problem is good.
