Proactively replace oil cooler lines?
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
Hello, my 2000 V70 NA appears to have the newer P2 oil cooler with the short rubber hoses and worm clamps. I'm at 200k miles and doing a coolant flush. Is it recommended to proactively replace these hoses? Has anyone had problems with them?
FCP says they're part number 30676906 for right / upper / inlet and 30713304 for left / lower / return. VolvoPartsWebStore and Tasca say the inlet uses part 31439470 (same shape) and the return is discontinued. Maybe they're going out of stock so I should try to get them from FCP now.
FireFox31
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
are the hoses soft. volvo used the Oetiker clamps for those to avoid the overtightening i see in your pic. If its not leaking leave it alone, but if your stressing about it just change it.
Been thanked: 4065 times
Easy hose to spec if we know the ID. The shape isn’t complex, so a straight piece of hose will do.
Definitely use oetikers on those hoses, I wrapped mine with exhaust wrap to protect them
I have to change out my bad clamps on mine, good reminder from this thread
I’m not sure we have ever had a failure in these. If you watch your coolant levels you will catch a seep. I don’t think Volvo brand hoses ever burst.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Those steel tubes have quite a lot of corrosion. Anyone know how thick they are? If only about 1 mm thick, I suggest changing the tubes for long term peace of mind.
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
The PO of my P2 put on new oil cooler hoses using cheap worm clamps. They also didn't wrap heat shield around them.
With the hoses removed I just had to wrap them with exhaust shield and use high quality Norma brand clamps:
https://www.amazon.com/NORMA-0136670402 ... B06Y2BPTTZ
https://www.amazon.com/Design-Engineeri ... r=1-4&th=1
I used that same wrap but my clamps were crappy. I’ve ordered the Normas which are OE Volvo
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
volvolugnut wrote: 22 Sep 2021, 08:36 Those steel tubes have quite a lot of corrosion. Anyone know how thick they are? If only about 1 mm thick, I suggest changing the tubes for long term peace of mind.
Spray with Noxudol 700, it will prevent any further rust for the remaining life of the car.
Measured the metal pipes on the cooler today
15mm OD
There is a 17mm flare in them so a 15mm ID hose is needed to seal
