Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Nevada1906 wrote: 25 Sep 2021, 16:58 Yay! The B5234T's accessory bracket fits!
It only gave me five out of six bolts, but I'm calling that a win.
Are you using the 850 accessories? You'll find that the tensioner will foul on the outer timing cover. We put an '02 LPT RN engine into my wife's '97 GLT and used the 850 intake/accessories.
If you mark out where the tensioner bracket hits the cover and cut that section out of the cover, it will allow things to nest together and fit properly.
Also, what are you using for engine management for the dual vvt?
Nevada1906
Year and Model: 1995 850 Turbo
Been thanked: 30 times
Post by Nevada1906 »
Chuck W wrote: 26 Sep 2021, 18:38
Yeah, I noticed the interference between the tensioner bracket and the front cover when I mocked up the accessory drive last night. Thanks for the suggestion about cutting the cover - that's what I'm gonna do. All the accessories fit fine - almost.
While the 850's power steering pump fits, the reservoir doesn't - the return line nipple clashes with the B5254T's intake manifold. I'm considering cutting it short and adding a 90-degree fitting to add a custom return line.
I'm using the ECU from a 2005 S60R to run this engine, probably with some kind of reflash to bypass the CEM immobilizer.
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
Chuck W
Post by Chuck W »
Nevada1906 wrote: 26 Sep 2021, 18:50
I'd be interested to see if you can get that to work.
manovlov
Has thanked: 675 times
Been thanked: 164 times
Post by manovlov »
I replaced the transmission fluid. Out, the black oil, in the Volvo brand new one... 2 seals -washers ... "and you're good to go "! like says our BuddyFriend Robby the DIY one !
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Changed my oil cooler hoses since they were likely original, also I wanted to do a flush on my cooling system. Ran a gallon and a half of clean water through before filling with BMW blue coolant. Same stuff as the old Volvo blue coolant, so might as well use the BMW coolant. Plus it’s easier to keep the whole fleet on the same stuff. I had Zerex G05 previously. No issues with it, I just like blue :D
I also replaced the turbo oil drain gasket and o ring. The o ring was leaking a little bit. Nothing major, but it was easy enough to replace it while I was down there.
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
abscate wrote: 26 Sep 2021, 16:07
Ethan Allen
They put the R in fuRnituRe….certainly the price point. It’s mind numbingly expensive stuff
SWMBO gets it for 5cents on the dollar via FBM
Oh, wait. A $100 couch I have seen; might be sitting on one now.
I'll bet your Seafaring experience helped with rigging that tops'l; with luck windage didn't blow you too far off course.
Has thanked: 1613 times
Been thanked: 4078 times
Yeah , that was quite the tie down. I took the slow road home at 35 mph
Make her fast, seaman abscate…..
Did a heater core bypass on the beautiful 1999 white S70 NA “WhiteLightning” for a neighbor who has a nasty heater core leak. More to come.
bmdubya1198 wrote: 28 Jul 2021, 10:24 Under an hour, not bad!
You still get to bill for 4 hours plus $100 shop supplies....
bmdubya1198
abscate wrote: 29 Sep 2021, 06:10
That's the way it goes when you work flat rate!
