After my most recent visit to a mechanic, they wrote on the bottom of the bill, "RE-TORQUE THE WHEEL BOLTS WITHIN 50-100 MILES".
My manual states that the proper torque is 100 ft/lbs. My only question is can I torque them while the car is sitting on the ground or do I need to have the weight of the car up on a lift?
Torquing wheel bolts
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 157 times
- Been thanked: 6 times
Mr. Detail
Yes it is a re-torque.
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
i check my bolts periodically, there are two types of wheel bolts the new style have captive washers where early cars had plain bolts (no washers) these bolts with no washers should be torqued less because the bite into your alloy rim and can lock.
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Would you ever put a schmear of anti-seize on those earlier type bevels, or does that mess up the torque number?
Mr. Detail
So since my P2 is a 2002 most likely with the old bolts, would you recommend getting the ones with washers?
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
Umm check first? If you have rounded out bolts or $80-$120 to burn then go ahead. Otherwise, there's other parts you should save up for.
- Has thanked: 987 times
- Been thanked: 1075 times
My opinion based on some incomplete knowledge of fasteners and bolt torquing, risk of incorrect (but close) torque on the lug bolt is less than risk of galling the threads or washer seat in corrosive areas. Use the schmear of anti-seize on threads and washer and check torque again at intervals.BlackBart wrote: 30 Sep 2021, 12:13 Would you ever put a schmear of anti-seize on those earlier type bevels, or does that mess up the torque number?
- 2550 Views
Last post by 93Regina
- 227 Views
- 1297 Views
Last post by Nevada1906
- 12 Replies
- 4684 Views
Last post by beigg
- 21 Replies
- 2671 Views
Last post by 98v70dad
