Nevada1906 1995 850 S60R m56 build thread
Nevada1906
Year and Model: 1995 850 Turbo
Been thanked: 30 times
Post by Nevada1906 »
abscate wrote: 27 Sep 2021, 06:11 Yes, work in progress. I was doing it on a Pad last night which was a pain
Abscate,
I'd like to add more posts to this thread, but I'd like to do it in order. When you get a chance, could you put my previous posts into this thread?
Thanks.
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
FWIW, the cover (PN 9135043) is still available brand new for about $46.
edit: I goofed on the PN and can't delete this post
Nevada1906
850oldschool wrote: 03 Oct 2021, 09:44 FWIW, the cover (PN 9135043) is still available brand new for about $46.
Thanks - I didn't know that.
It's funny how if you search the internet enough, unobtanium becomes, um, obtanium, I guess.
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Have you figured out the "No CEM" work-around for using the stock R ECU yet?
Been thanked: 4065 times
Think I got them all??
...fail, still some to come.
Nevada1906
Chuck W wrote: 04 Oct 2021, 07:48 Have you figured out the "No CEM" work-around for using the stock R ECU yet?
Haven't nailed it down yet, but most likely am going to have the ECU reflashed to delete the immobilizer.
Nevada1906
While Abscate's compiling all of my posts on what I've decided to call a 1995 "860R" into this thread, I figured I'd post more progress.
I mocked up the accessory drive...
...and all the 850 accessories fit. Except for the reservoir on the power steering pump - the output line nipple fouls on the intake manifold. I took the reservoir off the pump to get it to fit square on the bracket.
Oh well.
My plan is to modify the output nipple - not sure how yet - and get some Aeroquip hose & fittings from Summit Racing to build custom power steering lines.
Now it all has to come apart for cleaning. The accessories all ran when parked - we all know what that means, but hopefully it's true. I'll take the alternator and starter over to AutoZone and have them test each.
Fingers crossed...
Nevada1906
This is going to be a fairly rapid-succession series of posts, since I've gotten a lot done in the past couple of weeks.
Moving on.
Fitted the fuel rail.
Nevada1906
Yanked the front subframe out of the 860R and started cleaning it.
It was pretty oily and gritty - not quite Netflix's The Punisher gritty, but still ugly. With the subframe ouf of the car, I had to find temporary lodging for the front brake calipers. They're hangin' ten right now.
While I was wrestling the fuel lines out of the way, it occured to me that I can bin them because the S60R uses a returnless fuel system, and so doesn't need the 850's return line (or fuel pump). More on that later.
Then I removed the front mounts. A hydraulic press is NOT necessary for this job - A deadblow hammer, good aim and the WILL TO USE BOTH work fine.
Nevada1906
Cleaned the 860R's engine bay a little.
