850 code 424 tracs | leaking ABS pump | tracs delete Topic is solved
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 276 times
Been thanked: 84 times
Post by hausmeister »
And a happy end, at least for this Problem.
Bled the system, and after a test drive everything seems to work fine, no leaks.
No warning light set, I think that the brake-computer set those, and since I also replaced that (with non tracs)... at least it seems to be happy.
Only mod I did was disconnect the TRACS switch.
Thanks everyone for your support!
850 T5-R '95 auto Image
Has thanked: 2200 times
Been thanked: 1852 times
That was a tough problem to fix when parts availability is such a challenge. Well done!
hausmeister
Well, the normal ABS unit is still quite available, but the TRACS is impossible to get or for entirely unreasonable prices.
The challange of making a TRACS delete work turned out to be very simple, so I'm glad for that :D
