Setup the cams and glued the cam cover down, but the cams locked up
Something nit right, will work on later in week.
The Resurrection of (10/1998 to 01/2021, 11/21- 11/25) Elizabeth 1999 V70T5M56 Cylinder Head Job Topic is solved
- Has thanked: 1611 times
- Been thanked: 4075 times
- Has thanked: 317 times
- Been thanked: 531 times
Either the cams aren’t totally seated or there’s valve interference... is the crank at the alignment mark?
Finally got back to her after major job/house disruption
cleaned up cam cover and will setup tomorrow
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Are you in a place where we can get a welfare check ?abscate wrote: 13 Jul 2021, 20:00 Finally got back to her after major job/house disruption
We worry about Elizabeth.
Update after a very frustrating day - mostly self-flagellated..
Im stuck on the cam cover.
I have glued and unglued it four times now, and am finally coalesciing on a diagnosis.
First few times I kept booting my spatial relations and put the cams in every possible combination of wrong ways, but finally go tthem right and marked them with
Symptom was the cams were bound tight on tightening the valve cover.
But....
Finally got it right, and cams still wont move.
I had some flash rust on the cam bearings, so I cleaned them wih Scothbrite, greased up, they spin nicely in cover,
I stopped using sealant until I can get this problem solved.
Cams still lock up.
I then removed all the followers (small cups) so that the cams have no valve pressure, thinking perhaps the valves were stuck
It still binds when the cover is down.
I think my head has been destroyed by either a skimming or distortion in the machine shop.
Either way, head has to come off again.
But....
Cams still lock up.
- Has thanked: 312 times
- Been thanked: 818 times
Ugh. This seems a bitter pill, my condolences. At least you get to take it off yourself.
Did you check one cam at a time, does each bind alone? Not sure what that might reveal but at least you can check it.
- RickHaleParker
- Been thanked: 980 times
Did you send the cam cover to the machine shop with the head? Thinking somebody may of sent it back with a different cam cover.abscate wrote: 12 Oct 2021, 13:17 I think my head has been destroyed by either a skimming or distortion in the machine shop.
Active
Past
Past
If you check one cam at a time, be careful to not distort the cam cover.
When you are tightening it, at what point do the cams bind up? Seems strange.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Probably not relevant, but I'll throw it out there. When I was pulling cams from the junk yard car, the cams came right up and out easily. But when I went to pull the cams out of Sveedy, they seemed almost pressed in they were so tight. Made me wonder if the retailing seal rings were just a little bit snugger. If so then maybe your cams are not seating all the way down.
Just a thought...
Just a thought...
1999 V70 GLT
1999 V70 GLT
I really think they must have skimmed the cam cover mating surface. That's all I can think... I've never seen this happen before. That really sucks that it has to come back apart, but I don't think there's a way around it.
I've had some that are a pain to get out, and others that come out easily. Back and forth wiggling eventually gets them out, but they can be a little tight in there sometimes.Sveedy wrote: 12 Oct 2021, 16:08 Probably not relevant, but I'll throw it out there. When I was pulling cams from the junk yard car, the cams came right up and out easily. But when I went to pull the cams out of Sveedy, they seemed almost pressed in they were so tight. Made me wonder if the retailing seal rings were just a little bit snugger. If so then maybe your cams are not seating all the way down.
Just a thought...
- 21 Replies
- 6002 Views
- 1671 Views
- 32 Replies
- 8475 Views
Last post by SoCalV70T5
- 28 Replies
- 5782 Views
- 12 Replies
- 1528 Views
