That is 49 bytes. ( 49 bytes keys ) / 7 bytes = 7 keys. Only 7 keys used to decrypt the entire eeprom?
Vida CEM swapping
- RickHaleParker
- Been thanked: 980 times
Active
Past
Past
- RickHaleParker
Do you mean if you do the division in hex it will return the real part only? That would work.
Active
Past
Past
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
This is integer division. [0..6] / 7 = 0, [7..13] / 7 = 1, [14..20] / 7 = 2, etc.RickHaleParker wrote: 13 Oct 2021, 14:19Not all offsets are multiples of multiples of 7. Xor only works with real numbers. Imaginary number would xor.
vtl
Crypto key for EEPROM encryption/decryption is 0x3d bytes long, 61 in decimal.RickHaleParker wrote: 13 Oct 2021, 13:49 That is 49 bytes. ( 49 bytes keys ) / 7 bytes = 7 keys. Only 7 keys used to decrypt the entire eeprom?
I wrote C code that hopefully goes the same thing what the CEM machine code I found does.
- RickHaleParker
There is a term for that. It is Truncation. I recall Truncation as an operator way back in the 8 bit days.vtl wrote: 13 Oct 2021, 14:33 This is integer division. [0..6] / 7 = 0, [7..13] / 7 = 1, [14..20] / 7 = 2, etc.
Active
Past
Past
- RickHaleParker
You think the the key(s) are flash offsets 7FF00 - 7FF3C not 7FF00-7FF30 as stated by aaivar ?vtl wrote: 13 Oct 2021, 14:35Crypto key for EEPROM encryption/decryption is 0x3d bytes long, 61 in decimal.RickHaleParker wrote: 13 Oct 2021, 13:49 That is 49 bytes. ( 49 bytes keys ) / 7 bytes = 7 keys. Only 7 keys used to decrypt the entire eeprom?
Notes:
61 is not a multiple of 7.
49, 56, 63 are multiples of 7.
There are 2048 bytes in the eeprom. One would need to recycle the keys to decrypt the whole eeprom. 2048 / 7 = 292. Will need 292 keys to decrypt the entire eeprom. FF₁₆ = 255₁₀ , if you reduce a eeprom byte by more then 255₁₀ the results will be negative.
If the number of bytes in the key block is not a multiple of 7, it could loop back to the beginning creating a different set of keys then the first pass. With 61 bytes in the keys block, the keys would shift by two bytes each cycle.
Active
Past
Past
- RickHaleParker
I tried it with manual calculations. It is not working, at least it does not produce the same results as the files.vtl wrote: 13 Oct 2021, 06:47 They xor it with current eeprom byte offset divided by 7:
Something like this (haven't verified):Code: Select all
void eeprom_decrypt(unsigned char *eeprom, int len, unsigned char *crypto, unsigned char *decrypted) { for (int i = 0; i < len; i++) decrypted[i] = eeprom[i] ^ crypto[i % 0x3d] ^ (i / 7); }
Looks like each eeprom byte needs to be reduced before xor with flash key.
Use i/7 to reduce the eeprom byte as you read it from the file ?
Active
Past
Past
- RickHaleParker
What software did you use to produce the decrypt file?
Can we get a copy of it?
Active
Past
Past
aaivar
- Year and Model: v70 2015
my program will not work without activating a licenseRickHaleParker wrote: 14 Oct 2021, 21:47What software did you use to produce the decrypt file?
- RickHaleParker
Ok but what is the name of the program?
Is it something you paid for or something you wrote?
Can you do this.
- 1. Take a eeprom file and and fill it with all FF.
2. Take a Flash file and fill it with all FF.
3. Run the program using the two fake files.
4. Upload the Decrypt file here.
Run the software with the two files in the Zip file below. Then upload the resulting Decrypt file.
- RC detect.zip
- (125.55 KiB) Downloaded 148 times
Active
Past
Past
- 9435 Views
Last post by RickHaleParker
- 9512 Views
- 27 Replies
- 29398 Views
Last post by cn90
- 10 Replies
- 11063 Views
Last post by jonesg
- 6169 Views
