P80 Cam cover and cylinder head match marks location, index , indices , numbers
Been thanked: 4065 times
Documented where you can check that your cylinder head and your cam cover are a matched set.
They are stamped with small four numbers on the rear of the head and cover - they are faint,
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Nice! Thank you for that new info.
BMW 540i 2002
S70 Base 2000
The lore here is that cylinder heads and cam covers have to be precision machined and can’t be swapped.
Has anyone ever tested this by putting trying a non-matched over on a head
Cam journal bearing clearance isn’t as critical as crank and rod bearings , fir certain.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
^ Machine shop that is doing my engine told me the same thing. They insisted that I bring the cover along with its bolts so they could machine / match to the head, even though they're original to this engine. Never heard of that, but didn't argue.
1999 V70 GLT
