Slow Coolant leak between bottom of coolant tank and hose Topic is solved
lcc014
Year and Model: 855, 1995
Has thanked: 2 times
Been thanked: 11 times
Post by lcc014 »
In last oil change of my 1995 855 NA, I noticed that there were coolant leak (slow) out of the coolant hose under the coolant tank. I replaced the coolant hose (between tank and back side of engine). I drove the car last 2 days, and there are still have coolant around the end of the hose under the coolant tank. I tried to tighten the hose clamp as much as possible, but it still leak (slowly). The tank and hose were replaced together with Volvo parts 7 years ago. Now, with the new hose (also Volvo part), it still leak slowly.
Any idea what could cause the leak ? When I replaced the coolant hose, I did inspect the coolant tank, it looked fine to me, no crack.
Thanks,
Ching-Ho Cheng
Has thanked: 311 times
Been thanked: 817 times
My guess would be a cracked tank. I know you looked for that but if you didn't notice anything, it almost has to be the tank at this point. Let's see if there are any good ideas from others.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I also have had to replace the tank due to cracks. How old is your tank? If it's original, and it's like the one in my car and the old yellowed ones I've seen in the junkyard, it's likely to have a crack.
lcc014
Post by lcc014 »
jreed wrote: 13 Oct 2021, 05:34 I also have had to replace the tank due to cracks. How old is your tank? If it's original, and it's like the one in my car and the old yellowed ones I've seen in the junkyard, it's likely to have a crack.
This tank is about 7 years old, not the original. Original had cracks so that I replaced it with this tank. Bottom of the tank is "dark/yellow". I could not see any cracks. The leak happened after car was driven (including waiting in front of traffic light, etc) for a while. In other words, leak happened under pressure and high temperature.
Thanks,
Ching-Ho Cheng
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 276 times
Been thanked: 84 times
Post by hausmeister »
Check the small overflow nipple/hose. On mine the nipple on the reservoir was clogged, I used a drill bit to clean it. It had a few drips around that area sometimes, luckily I noticed this. worth a try to check this :)
850 T5-R '95 auto Image
lcc014
Post by lcc014 »
hausmeister wrote: 13 Oct 2021, 08:28 Check the small overflow nipple/hose. On mine the nipple on the reservoir was clogged, I used a drill bit to clean it. It had a few drips around that area sometimes, luckily I noticed this. worth a try to check this :)
The little hose is "new", less than 6 months old along with the new clamp. Here are some pictures of the area where the leak happens.
Found leak during oil change; old coolant tank and old coolant hose
Old coolant tank and new coolant hose and leak
leak around the area between bottom of tank and hose end; then dripped down along the hose
better view with more light
Has thanked: 2199 times
Been thanked: 1852 times
Is there a metal sleeve inside the lower hose outlet? It is meant to be there to prevent the plastic hose being squeezed so it is not round. If it is missing, then with that type of clamp it is not possible to get it to seal fully.
Also check it is not leaking from the level sensor.
If all that fails, then there has to be a small crack in the pipe where it meets the main header tank.
You could also see if you can get a different pipe clamp like those used on fuel hoses which clamp more consistently around a hose to prevent leaks.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Buy a new Volvo original tank
BMW 540i 2002
S70 Base 2000
lcc014
Post by lcc014 »
scot850 wrote: 13 Oct 2021, 16:37 Is there a metal sleeve inside the lower hose outlet? It is meant to be there to prevent the plastic hose being squeezed so it is not round. If it is missing, then with that type of clamp it is not possible to get it to seal fully.
Hi Neil,
Yes, there was a metal sleeve inside the hose outlet. I did not pay attention to it and to check whether it was still round or else.
When I replaced the hose, I did unplug the level sensor but did not remove it from the tank. AFAIK, there was no coolant residue around the level sensor area. I will try to find the fuel hose type clamp to try when the new tank arrive.
Thanks,
Ching-Ho Cheng
lcc014
Post by lcc014 »
kallekula wrote: 13 Oct 2021, 18:18 Buy a new Volvo original tank
Yes, I ordered it yesterday from Boston Volvo.
Thanks,
Ching-Ho Cheng
