Hey, bit of an embarrassing question here but what is the big air pipe going over the engine called? This is from a 2005 S60 T5.
I need to replace mine and I'm having a hard time finding the exact part.
Found a replacement at the local yard but i think it was from a non-turbo model - the diameter of the endpoints come slightly different.
Looking for "Air Intake" leads is usually leading me to the pipe going from the air filter box, etc...
Thanks
What is the big Air Pipe over the engine called? Topic is solved
lunar90
- Year and Model: 2005 S60
Yep that helped, thank you very much. Cataloged as "Upper Pipe" in volvo parts (8638967) as well.
for reference:
https://www.volvowholesaleparts.com/oem ... wtbDUtZ2Fz
- Been thanked: 4071 times
There are two or three flavours of turbo, each with a different pipe, so you need to match it up carefully by numberlunar90 wrote: 14 Oct 2021, 00:18Yep that helped, thank you very much. Cataloged as "Upper Pipe" in volvo parts (8638967) as well.
for reference:
Blessed are those who call it the 8638967, which is much easier to search than:
Pipe
Induction pipe
Big fat pipe
Black pipe over top of engine
- Has thanked: 987 times
- Been thanked: 1076 times
I just call it the thingy you have to take off first before you do anything to the engine.
volvolugnuty
volvolugnuty
Jonboy74
- Year and Model: V70 2.4T, 2002
- Has thanked: 119 times
- Been thanked: 15 times
^^^^^^THIS^^^^^^volvolugnut wrote: 14 Oct 2021, 09:19 I just call it the thingy you have to take off first before you do anything to the engine.
volvolugnuty
And for anyone who happens to look for this same part for a 2002 V70 2.4T, the part number is Pipe - Volvo (1282865)
But what I would REALLY love to know is, what is the part number for the two M5 bolts with the captive washer that is used to hold said pipe into place. No one I've asked so far seems to know....including the dealership! (I lost one down into the recesses of the front of my vehicle a while back....)
Jonboy
This question has been answered here before, maybe in the last year. Try searching this forum more.
Lets try the Volvo WEb store parts engineJonboy74 wrote: 14 Oct 2021, 16:40^^^^^^THIS^^^^^^volvolugnut wrote: 14 Oct 2021, 09:19 I just call it the thingy you have to take off first before you do anything to the engine.
volvolugnuty
Jonboy
11, 20,21 ?
Jonboy74
Thanks abscate - 11 is an M6, so that's not it. 20 MIGHT be a possible fit, but not sure. I've asked for the thread dimensions and length from the team at FCP Euro.
What came in the car is a machine screw with a T25 pan head and a captive/free spinning washer. Appears to be an M5 x 20. Part 21 is an M5 x 20, but without the captive washer (yes, I'm being picky
Pictures below.
Thanks!
Jonboy
- BlackBart
- Has thanked: 967 times
- Been thanked: 922 times
I always measure bolt length from the underside of the head to the end.
- 5636 Views
- 5163 Views
Last post by darrylrobert
- 870 Views
Last post by rspi
- 982 Views
Last post by rhalkyard
- 498 Views
Last post by Ozark Lee
