I have a 2011 Volvo XC70 with the position light failure message. Only LH front bulb inop. Bulb/socket/ground all check good. No voltage confirmed at plug.
The rear LH position light works.
The wiring diagram shows the power coming out of the CEM at C1:18.
I cannot find a fuse on the CEM for parking lights. Does anybody know its location?
Does anybody know which connector is C1 ? It would be worthwhile to cycle the plug.
Thanks!
Volvo position light issue
davewave365
- Year and Model: 2011 XC70
- Been thanked: 2 times
davewave365
Anybody? Buller?
- Has thanked: 987 times
- Been thanked: 1078 times
I have the same recurring issue with a right rear position bulb on 2001 V70. Electrical grease helps for a while. Only wiggling the bulb a few times is a consistent short term fix.
On rereading, you have a power supply, not contact problem. Not much help here.
davewave365
Does the CEM shut off power if the resistance/draw is not correct? Perhaps that is why I got no voltage?
- 5015 Views
Last post by Oly850
- 1429 Views
Last post by RickHaleParker
- 59 Replies
- 2491 Views
Last post by CoupeC70
- 9858 Views
Last post by iamhives
- 834 Views
Last post by lummert
