1996 850 Turbo Automatic, $700 or best offer
bugs11
Year and Model: 850 1996
Post by bugs11 »
ODO was broke and stuck at 74k+ miles when I bought it. I'd guess it has around 200k miles on it. I bought the car in 2011 for the kids to drive back and for to high school. They ended up taking it to college with them, but now it's back home with me.
The good; always starts, runs great (engine is solid), lots of newer parts; redid the head gasket in Fall of 2015, replaced PCV Breather system, water pump, timing belt, etc.., also new ignition module, rebuilt ABS module, new front CVS axles, new heater core, new turbo oil lines, new front and rear struts, engine torque mounts. front brake calibers, brake pads, rotors. Two brand new front tires and the new owner gets the Mann filters I have on hand for it.
The bad; recently developed a battery drain. I've been unhooking the negative power cable.
The ugly; driver side front bumper damage, one of the kids hit a parking garage support when backing up witch pulled the bumper away a bit and tore the wheel liner that then ripped up the CVS axle boot. Also the driver leather seat has tears and holes.
I'll post some pictures later and the list of parts I've purchased over the years from FCP Euro and RockAuto.
bugs11
Post by bugs11 »
List of parts I've purchased over the years for the car. Taken from receipts.
Sept 24, 2013 - 268.22
Volvo Strut Assembly Sacks SAC-553058 Qty: 2
Volvo Strut Bolt VOL-982845 Qty: 4
Volvo Strut Bolt Lock Nut Genuine VOL-985870 Qty: 4
Volvo Sway Bar Link Meyle MEY-5160600000HD Qty: 2
Volvo Strut Bump Stop Professional Parts PPS-72430067
Sept 12, 2014 - $107.79
Volvo Brake Disc Bosch BOS-53011385 Qty:2
Volvo Brake Pad Set - Bosch BOS-BP31 Qty: 1
Aug 19, 2015 - $567.08
Volvo Oil Dipstick Professional Parts PPS-21431921
Volvo Timing Belt Kit Contitech KIT-TBKIT252-OEM
Volvo Engine Coolant Thermostat VOL-271664
Volvo Water Pump HEPU HEP-P056
Volvo Oil Filler Cap Gasket ELR-045721
Volvo Oil Drain Plug Washer OEM-977751 Qty: 3
Volvo Engine Oil Filter Mann MAN-W917 Qty: 3
Volvo PCV Breather System Kit Genuine KIT-850T200
Volvo Return Cooling Hose Genuine VOL-30713305
Volvo Turbo Inlet Cooling Hose Genuine VOL-6842190
Volvo Copper Crush Washer ELR-110353
Volvo Seal Ring VOL-947621 Qty: 2
Aug 25, 2015 - $122.96
Volvo Timeing Cover Genuine VOL-9135040
Volvo Heater Hose Outlet PPS-87436847
Volvo Heater Hose Inlet PPS-87436849
Aug 27, 2015 - $35.87
Bosch Spark Plug BOS-4028 Qty: 5
Volvo Seal Ring Genuine VOL-947621 Qty: 8
Volvo Expansion Tank Cap GAT-31329
Sep 11, 2015 $18.53
Volvo Copper Crush Washer ELR-110353 Qty: 6
Mar 15, 2016 $97.24
Volvo Ignition Switch Genuine VOL-9447803
Volvo Air Filter Mann MAN-C35148
Volvo Cabin Air Filter Mann MAN-CU2650
Volvo Side Moulding Clip Genuine VOL-6806505
Mar 31, 2016 $54.47
Volvo Expansion Tank Hose Genuine VOL-9135267
Volvo Transmission Cooling Hose Retaining Kit KIT-6842411K
Apr 09, 2016 $128.97
Volvo Torque Rod Mount Genuine VOL-8631159
Volvo Torque Tod Bushing Genuine VOL-9434263
Volvo Engine Torque Rod Genuine VOL-9141042
May 05, 2015 $337.95
Volvo Axle Shaft Front Left USA-AX8577
Volvo Automatic Transmission Shaft Seal Qty: 2
Volvo Axle Shaft Front Right USA-AX8578
Vovlo Fuel Filter BOS-0450905216
Feb 14, 2017 $257.80
Volvo Control Arm Kit 2 Piece KIT-P80CAKT2P2
Volvo Serpentine Belt CON-6K1743
Volvo Engine Oil Filter MAN-W917 Qty: 4
Volvo Oil Drain Plug Washer OEM-977751 Qty: 4
Jul 11, 2017 $47.47
Volvo Fuel Pump Relay KAE-3302230 (never used)
Apr 21, 2018 $115.55
Volvo Heater Core MAH-AH106000P
Volvo Heater Core O Ring SAN-3545586 Qty: 4
Sep 11, 2018 $49.36
Volvo Strut Mount Spring Seat Lemforder LEM-2015201
Volvo Air Filter Mann MAN-c35148
RockAuto
Apr 03, 2017 $167.39
A-1 CARDONE Front Brake Caliper 19P1732
A-1 CARDONE Front Brake Caliper 19P1733
Apr 13, 2017 $101.69
SACHS Rear Shock Absorber 105828 Qty: 2
Aug 03, 2020 $76.14
POWER SELECT Starter Motor 17508N
