Welcome!!
First Step - Stage Zero - get all your tuneup stuff and fluids up to date, and your PCV checked and updated.
Next step - Accept the car for its 16X HP, work an extra job to look for a 'R' Project, or if you are really cool, a T5.
There might be Blue R for sale in Alberta soon - search under 'Spawn of Satan'
lastly - adapting an NA (non turbo) to a Turbo..........doesnt happen.
first car
- Has thanked: 1511 times
- Been thanked: 3829 times
Re: first car
SirBrickWagon
- Year and Model: 1997 Volvo 850
- Has thanked: 7 times
- Been thanked: 11 times
wasn't planning on turboing my car, as i work minimum wage and just need cheap/free modifications to increase power
1997 Volvo 850 Wagon (Non-Turbo) with too many problems to count
- Clemens
- Has thanked: 475 times
- Been thanked: 219 times
if it has an AT, the cheapest power mod for a NA is a manual swap. It is a lot of work, but cheap if you find a wrwcked parts car. Everything else that noticeably improves the power of an 850 NA costs ALOT of dough.
Enjoy it for what it is and get it to stage 0 as abscate suggested. If it is too slow for you, keep looking for a Turbo. And as previously stated: Upgrading an 850 NA to Turbo is beyond the skillset of most mortals.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
- ZionXIX
- Has thanked: 65 times
- Been thanked: 194 times
Doing as much stage zero stuff as possible will add small amounts of lost HP. Every brittle rubber vacuum hose is a potential vacuum leak. Rolls of good quality silicone hose can be found fairly cheaply online. The PCV can be removed, inspected and cleaned essentially for free but requires removal of the intake manifold. I would have a spare intake gasket on hand incase the old one disintegrates. Check the spark plugs for wear and gap if necessary. Clean every electrical connection you can get your hands on.
- Has thanked: 930 times
- Been thanked: 1005 times
Fat tires and air shocks in back for that drag racer look. Remove the muffler.
Wait. It is no longer 1970.
volvolugnuty
volvolugnuty
Seriously, most of us at MVS are not in to performance modifications. You may better find performance information at swedespeed.com
SirBrickWagon
yea i just meant cheap stuff like drilling holes in the airbox, stuff like that. planning on restoring the 850 and eventually doing an engine swap as mine is estimated over 500,000km
- Has thanked: 1858 times
- Been thanked: 1718 times
Not sure why you would drill holes in the airbox? All that does is then draw hot air in from the engine bay which warns the air entering the engine reducing charge compression.
I regularly laugh when I see un-boxed cone air intakes, particularly at the back of the engine bay. Nuts!
- RickHaleParker
- Been thanked: 958 times
Hot air is less dense. The lower the density the lower the amount of Oxygen in a given volume. The less Oxygen, the less fuel the engine can burn. That is why hot air reduces performance.
The function of a Turbo is to cram more Oxygen into the cylinder so the engine can burn more fuel. The function of Intercooler is to dump heat produced by the Turbo heating the air ( anytime you compress a gas it will heat up ) . Dumping the heat increases the air density up and above what the Turbo did and increases the amount of Oxygen for a given volume up and above what the Turbo did alone.
SirBrickWagon
that's why i would drill holes in the front of the airbox to draw in fresh air from the frontRickHaleParker wrote: ↑27 Oct 2021, 13:15Hot air is less dense. The lower the density the lower the amount of Oxygen in a given volume. The less Oxygen, the less fuel the engine can burn. That is why hot air reduces performance.
