Carbon box 95 850 N/A
- Danonly55
- Year and Model: 1996 850 sedan
- Has thanked: 23 times
- Been thanked: 4 times
What would happen mechanicly if my carbon box and fuel tank vent were not connected ?
2014 Ford 3.5L ecoboost XLT
1995 Volvo 850 wagon GLE
Life is tough, but it's tougher when your stupid'
" John Wayne
" John Wayne
- Has thanked: 1611 times
- Been thanked: 4075 times
You are going to Vent gas fumes into Mother Nature and she will angrily set a code for an evap error in retaliation
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Better than even odds that it will disconnect itself naturally, then you get to play Whacka-Mole-vacuum hose.
- Danonly55
Ok , don't want to piss off mother nature. The car came with a replacement carbon box, purge line not hooked up or vent from tank not hooked up. No codes at all. It also passed emmissions
. The car does have all new vacuum lines instaled when I did the PCV system. It still doesent have much pickup when I have to slow down on the freeway and then get back up to speed... slow to get back up to speed, she's a dog/pig/snail. Any Ideas guys ??
" John Wayne
" John Wayne
- Has thanked: 987 times
- Been thanked: 1078 times
Maybe she hangs out with Shotzie the Diesel Mercedes too much?
Assume it has had routine maintenance? Plugs, wires, etc.
badboye46
- Year and Model: 1994 850/91 240
- Been thanked: 2 times
I know this is an old post, but I have a 94 NA sedan and have found that there may be the same problem with my car, my charcoal canister is connected and recently after having the same problems you are describing I found a missing plug (or vacuum cap) missing on my canister, the car idles fine runs fine once I get up to speed. But that’s where it sounds a lot like your problem. There is a vacuum line connected to the top of your air cleaner box top held on by two screws, one vacuum goes to the vacuum tree on the intake and another on that piece is teed and goes to the charcoal canister, these lines connect right under the battery tray. So if you are running the existing charcoal canister; as you said you have a spare, and the fuel vent line is disconnected and other lines to the vacuum canister, that is now a vacuum leak and could explain the “no pep” issues with your car should you still own it.
- 2287 Views
Last post by Bloitz
- 163 Views
Last post by Drott57
- 2486 Views
- 11 Replies
- 6638 Views
Last post by June
- 704 Views
Last post by SuperHerman
