Wheel size question
AlanS
Year and Model:
Wheel size question
Post by AlanS »
My car: 2006 XC70 Ocean Race...17" wheels. I have the opportunity to purchase wheels from a 2007 S60- 17".. It is quite a distance to pick them up...maybe a few hours. How do I know if those wheels will fit my car? The 17" is correct, but what about the width and offset? Help...I want to let the fellow know ASAP
Has thanked: 1856 times
Been thanked: 1718 times
Are the wheels Volvo originals or aftermarket?
On the back of Volvo OE wheels the size and offset should be stamped. It will say something like 7 x 17 x 49
The 7 is the width in inches. For your car it will probably have 7.5" - Obviously it makes sense to remove a wheel and check on your own car.
17 is the wheel diameter.
The 49mm is the offset. A larger number means it will sit closer into the inner fender.
The one thing to watch is the center bore which I don't think is stamped on the back. For your car it is 65.1mm if I recall. 08 and on P3 models (yours is a P2) have a 63.5mm center bore.
Ask the seller to take pictures of any numbers on the back of the rim and send them to you.
The bolt hole positions should be 5 x 108mm
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 42 times
Post by darylrobert »
fairly sure all Xc90 Xc70 V70 S60 S80 wheels are interswappable. just the load bearing might be different, i have R wheels on my XC, it makes it go faster
Has thanked: 1511 times
Been thanked: 3827 times
Much faster but if you only put them on one side it drives in circles…
