2005 XC70 2.5T Coolant Capacity Topic is solved
iamhives
Year and Model: 2018 V90 T5 R design
Been thanked: 6 times
Post by iamhives »
I have searched various places and can't get a definitive answer! I also looked in my owners manual and for some reason it states all other fluid volumes except coolant?
I read various numbers from 7L up to 9L. I have an 2.5T and the most often quoted number is 8L but wanted to verify since there seems to be lots of divergent information out there.
Reason I want to know is I'm going to be flushing completely with deionized water and need to know how much 100% coolant to add in the last flush/fill to get the 50/50 proportion.
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
I just did mine. After a full flush I added about 4 litres of the blue concentrated Volvo stuff and about 2 litres distilled water, I’m guessing there was about 2 litres left in the engine of water before I added the coolant because my tester showed it was good down to -37 C.
2003 XC 70 (sold)
iamhives
Post by iamhives »
Been doing more coolant research. Its a controversial topic! It seems while its not ideal, HOAT and OAT and be mixed and will not result in a chemical reaction? And while our old Volvo's used HOAT originally it seems newer cars us OAT and that its preferable or European cars ? So is it OK to run OK to run OAT (e.g. in my new cars case Peak Pink - which is OAT) in our P2's?
Has thanked: 311 times
Been thanked: 817 times
I know it's not really what you asked but: I would run Zerex G-05 (HOAT, reasonably cheap, easy to get locally almost anywhere) or the Volvo coolant (similarly cheap from FCP Euro, but have to wait for shipping). I don't mean mix them - run one or the other.
About cooling system volume, I have been going by the 07 XC70 user's manual (total capacity 9.3 quarts = 8.8 liters). This does mean you need to pick up and crack into a second bottle of coolant.
Screen Shot 2021-10-31 at 7.50.45 PM.png (98.16 KiB) Viewed 5001 times
iamhives
Post by iamhives »
Just to close this out. I ended up flushing multiple times (maybe 6) with distilled water, letting teh water cycle thru the engine with thermostat open each time. Then on the final flush let as much distilled water drain as possible from the radiator petcock (about 4.5L) and added 148 fl oz (1.16 gallons, 4.38 L) of Volvo coolant. The resulting mix had a specific gravity reading on my refractometer that indicated -45C freezing point which based on graphs I found for ethylene glycol indicates about 55/45 mix. Doing the math that means the overall capacity is 8L. Obviously not exact but certainly in the ballpark. If I understand it correctly while 55/45 lowers the freezing point more than 50/50, it reduces the specific heat capacity. I also believe anything more that 60 or 65% coolant and the freezing point start to rise again so 50 - 55% is about right. All a little too precise I know but now I know where I stand I will top up as necessary with distilled water until the dilution goes down to 50/50.
Has thanked: 1609 times
Been thanked: 4065 times
You have to live in a really pathological place to not get away with a single gallon of coolant in a P80. We very rarely dip below 0F here so running 40-44% coolant is fine.
Wind chill is irrelevant to coolant planning btw, we had a ( non Volvo ) dealer SA who used to upsell coolant changes based on wind chill.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
abscate wrote: 04 Nov 2021, 00:50 You have to live in a really pathological place to not get away with a single gallon of coolant in a P80. We very rarely dip below 0F here so running 40-44% coolant is fine.
yeh "Feels like" , thermometers don't feel or fear anything.
