Fuel Rail Schrader Valve Q&A Period
bill b
Year and Model: 2006 XC70
Post by bill b »
Hi, Gang,
While proceeding with fuel pressure testing, I removed the cap from the Schrader valve at the end of the fuel rail.
Fuel flowed out quite readily. Does anyone know part number? Is this the same size as the others in the fuel lines?
Thank you.
Bill
Been thanked: 504 times
Post by cn90 »
Are you asking about the cap or the "valve core".
I think the valve core is the same as a tire valve core (please verify).
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 57 times
Been thanked: 39 times
Post by EngineeringBloke »
Please let us know what pressure you see when you test. My 2006 S60 2.5T starts at 55 PSI but drops to 43 after about 30 seconds, measured on Torque and with an autopart store loaner fuel pressure gauge. Wondering what others see.
Been thanked: 4067 times
EngineeringBloke wrote: 03 Nov 2021, 09:41 Please let us know what pressure you see when you test. My 2006 S60 2.5T starts at 55 PSI but drops to 43 after about 30 seconds, measured on Torque and with an autopart store loaner fuel pressure gauge. Wondering what others see.
there is both a pressure spec and a drop spec after 30 minutes - I think your pressure is ok, but you are failing the drop test.
viewtopic.php?f=9&t=96224&p=565820&hili ... ec#p565820
