That torch picture reminds me of another torch failure of mine. I was cutting a tube with the torch while wearing a frayed jacket. The sparks down the tube ignited the coat. Fortunately, I was wearing leather gloves and slapped out the flames on the jacket. The jacket went in the trash as soon as the flames were out.
Always wear PPE (Personal Protection Equipment). Including SHOES.
The great P80 Volvo Bloopers - Idiots - Fails thread - June 2023
- Has thanked: 987 times
- Been thanked: 1078 times
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
I did the same mistake on a Mark 4 VW Golf wagon, luckily my mom noticed a clunking from the rear. I had torqued them down, but I guess they need quite alot more torque than one would suggest.abscate wrote: 26 Oct 2021, 10:23 Dumba**** failed to torque the caliper attach bracket correctly to the rear axle. It got loose, the caliper swung up and machined out the alloy wheel, which blew the tire, and then caught in the alloy, fracturing the rotor, bracket, and tires.
I suspect I put the bolts in and never got around to torquing them, due to a long day and user fatigue. They drove for about two months/900 miles
I like welding in bare feet - it keeps you aware of where the metal is going
Just like the wheel bolts on the VW T4s. I know no T4 owner who didn't have them come loose at some point. Honestly, who feels comfortable torquing wheel bolts to 180 Nm ...
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- RickHaleParker
- Been thanked: 980 times
I do .. 180 Nm is only 134 ft-lb. Just 34 ft-lb more then I torque Volvo Lug bolts.Clemens wrote: 27 Oct 2021, 02:48 Honestly, who feels comfortable torquing wheel bolts to 180 Nm ...
Active
Past
Past
- Has thanked: 2209 times
And a lot less than the 350ft/lb+ I had to use to remove the lug nuts from my wife's Kia after a visit to the dealer!
- Clemens
How did the bolts like that? I removwd a way overtorqued wheel bolt once and it was basically ripped apart and the lower part was only hanging on with a single thread. Kinda hard to explain, but fascinating to look at.scot850 wrote: 27 Oct 2021, 11:40 And a lot less than the 350ft/lb+ I had to use to remove the lug nuts from my wife's Kia after a visit to the dealer!
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Surprisingly they all survived. Now the Kia spec for torque for alloy wheels is 69-80 ft/lb!! After that I always checked the wheel lugnuts after a visit and made it clear I would before handing the car over. When it happened again, I stopped using the dealer as that was on top of striping the oil pan bolts and then trying to fudge a repair which only lasted one day before leaving a pool under the car of fresh engine oil. They then tried to blame the dealer I bought it from. I hate that dis-honesty.
- Has thanked: 1611 times
- Been thanked: 4072 times
If you don’t lube the cam thrust bearings on both the axial and the thrust surfaces with heavy grease, you can take the cam cover off and on six times and the cams still won’t rotate.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Nothing like practice to perfect a task.abscate wrote: 05 Nov 2021, 04:48 If you don’t lube the cam thrust bearings on both the axial and the thrust surfaces with heavy grease, you can take the cam cover off and on six times and the cams still won’t rotate.
The rest of the process should seem routine now.
Until I knuckled down and understood cam flank angle , I had timing belt removal on my T5 down to 6 minutes
Now you are a confirmed flanker!
- 68 Replies
- 47980 Views
Last post by bmdubya1198
- 2073 Views
Last post by kippster41493
- 31 Replies
- 13629 Views
Last post by ToriWhite
- 872 Views
- 9 Replies
- 13050 Views
