Has thanked: 2215 times
Been thanked: 1853 times
If the bolts are not rusted. I'm hoping they are going to be ok as I replaced the 2 slider bolts maybe 3 years ago. Actually, they may be newer than that as our son had a prang in it maybe 2-3 years ago and it got a new bumper cover.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
There are only 2 bolts holding the bumper. The rest is plastic push pin clips and a couple of torx screws. I can do my bumper out and then back in with eyes closed, in under 5 minutes. It is that easy.
wch2032
Year and Model: 06 XC70
Has thanked: 11 times
Post by wch2032 »
I replaced my oil cap gasket (which was pretty hard) and upper engine mount (rubber insert moved freely inside). Now I'm thinking I need to do the strut brace mounts as they seemed pretty soft–or is this normal?
Also thinking of swapping out the rear shocks. Does anyone know if I need a spring compressor for this on a 2006 XC70?
06 XC70 - 251K
Has thanked: 1613 times
Been thanked: 4078 times
wch2032 wrote: 12 Nov 2021, 23:41 I replaced my oil cap gasket (which was pretty hard) and upper engine mount (rubber insert moved freely inside). Now I'm thinking I need to do the strut brace mounts as they seemed pretty soft–or is this normal?
Big pry bar to pull the control arm down. I stood on a 6 foot bar with big fat guy on the end of a 4-5:1 lever to get this done
vtl
Post by vtl »
They are soft by design, to keep vibrations under control.
wch2032 wrote: 12 Nov 2021, 23:41 Also thinking of swapping out the rear shocks. Does anyone know if I need a spring compressor for this on a 2006 XC70?
Yes. You still can take the whole assembly out w/o compressor, but changing the shock would require using a spring compressor.
This type of compressors works very good: https://www.ebay.com/itm/165021127842?h ... SwBgRhKHhC
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
vtl wrote: 13 Nov 2021, 05:22
Thank you vtl with my project; this may help https://www.matthewsvolvosite.com/forum ... =9&t=91242
Has thanked: 312 times
Been thanked: 818 times
abscate wrote: 13 Nov 2021, 01:52
I used really heavy duty tie-down straps and cinched the rear control arms together and down, did not use a pry bar except when popping out the shocks. Yes on compressor. 07 XC70.
vtl wrote: 11 Nov 2021, 19:46 There are only 2 bolts holding the bumper. The rest is plastic push pin clips and a couple of torx screws. I can do my bumper out and then back in with eyes closed, in under 5 minutes. It is that easy.
This is spot on. I just changed the washer pump on my S60, had to unhook the bumper and pull away on passenger side to do it. Seems like a hassle until you see how it's done. Then you get in there and it's super easy.
Stu70
Year and Model: 2006 Sonic VR GT
Has thanked: 34 times
Been thanked: 26 times
Post by Stu70 »
Took out radio for the 4/5 time for intermittent fault of no display.
Discovered my sun glasses are polarised, re instal radio.
’User error - no fault not found’
1998 S70 10v BiFuel - Sold
2006 Sonic V70R - “this is going to be expensive “
We used to diplomatically file those under OHIO
OPERATOR HEAD IN ORFICE
