P80 headlights Possible to Remove Headlight Reflector, rechroming discussion 8628402 8628403
- Has thanked: 2857 times
- Been thanked: 1332 times
With a thin enough material, I think I could reduce the wrinkles to a possibly passable low % of surface area. I'm good with an X-Acto knife, but I've never covered a concave object.
- RickHaleParker
- Been thanked: 979 times
Perhaps Reflective Mylar. Mylar is good to 200℃
Active
Past
Past
Requirements:
heat resistant to (?)
reflectivity, enough (?)
under $50
easy enough DIY application
long life
Any others?
under $50
long life
Any others?
- RickHaleParker
What I thinking is:matthew1 wrote: 14 Nov 2021, 18:19 Requirements:
under $50
long life
Any others?
- 1. Clean the reflector.
2. Attach a vacuum source to the port the bulb goes in.
3. Attach or clamp the film to the other side of the reflector, get a air tight seal.
4. Heat the film and draw it with the vacuum source.
5. Remove the heat and vacuum let it cool.
Active
Past
Past
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Seems like this would work fine. And a roll would do 72 cars !
1999 V70 GLT
1999 V70 GLT
Heat gun hitting the outside of the housing maybe?
dj_v70
- Year and Model: v70 2003
- Has thanked: 7 times
- Been thanked: 23 times
Another option, but not as cheap as tape (or film). Heck it is close to the price of a TYC headlight ...
"Great For Re-Plating Headlight Reflectors"
https://www.amazon.com/E-Z-Way-Restorat ... B00HFER3AE
- RickHaleParker
I would think that by the time a heat gun got it hot enough the reflector would melt.
Radiant heat lamp would have a more even distribution ... infrared space heater aimed at the film?
Infrared heat just what the light falls on.
Active
Past
Past
Aimed at the back or the front? The front will reflect most of that energy.RickHaleParker wrote: 14 Nov 2021, 18:57I would think that by the time a heat gun got it hot enough the reflector would melt.
