Maybe someone here might have answer to this - Fault Trace Issue.
https://www.matthewsvolvosite.com/forum ... 43#p588043
Fault Trace Not Working
- Has thanked: 311 times
- Been thanked: 817 times
Have you used this combo before, software and Dice tool?
Try it with the car running, the voltage is stably in range that way, see if it helps.
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
Yes many times in the past, I have. I have used the combo in the two 01 XC70s.erikv11 wrote: 25 Nov 2021, 12:17 Have you used this combo before, software and Dice tool?
Though two times back, I noticed the the two 01 XC70s "kept" the same database.
The current reading keeps showing as the reading for any profile I selected.
I think I used it with the car (XC90) running, I always do with the XC70s, to keep the battery juice.
Besides the Fault Trace, what else can I try to see if the car is really connected?
Oka
Found the culprit!Oka wrote: 25 Nov 2021, 12:04 Maybe someone here might have answer to this - Fault Trace Issue.
I went back to VIDA to check the settings. The wrong region (Partner group) was showing.
As soon as I selected the correct region, Bam, Fault Trace got highlighted under the Diagnostic tab.
So, all is fine now.
Thanks all.
- 2498 Views
Last post by Oka
- 1989 Views
Last post by MAC99
- 2480 Views
Last post by TripleThreat719
- 2011 Views
Last post by Ozark Lee
- 1997 Views
Last post by EngineeringBloke
