2008 XC70 Air-conditioning compressor noise
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
rollingon
Year and Model: V70 XC 1998
Post by rollingon »
Hello. There is a noise in my 2008 XC70, that has been getting steadily more obvious, that appears to be coming from the air-conditioning compressor. My initial fear was that the noise was coming from the transmission, as it sounds like a whine that increases and desreases with engine revs, however, I realised that it stopped when I turned the A/C off. It isn't the fan as the noise doesn't happen when the fan is running without the A/C.
Does anyone know why the A/C in the car would be making this noise? Due to the change in pitch with revs, and therefore the pulley/belt, my sense is that it is coming from the compressor. Does this seem right, and why would it be happening? Is it possible that the compressor simply needs to be recharged, or am I looking at having to replace it.
Any input and suggestions welcome.
Thank you.
2008XC70
Year and Model: XC70 2008
Post by 2008XC70 »
Did you ever get this fixed? Mine has started making a noise too. It almost sounds like the same noise that a power steering pump makes when its low on fluid.
Could be a clutch issue? Or low lubricant in the pump?
2008XC70
Post by 2008XC70 »
Someone made a video, mine sounds similar but not nearly as bad.
bobjet
Year and Model: 2008 XC70
Post by bobjet »
I've got a similar issue with the same car. I'd love to hear that I could just replace the AC clutch and bearing. What did you all do to fix the issue? I'm about to replace the serpentine belt so I'm formulating my "plan" to solve all this as economically as possible while replacing all the recommended do dads. There's a guide here in the forum that I plan to follow that is just stellar.
pierremcalpine
Year and Model: V40 2003, V70 2010
Has thanked: 2 times
Been thanked: 5 times
Post by pierremcalpine »
When I did my serpentine belt I asked the dealer whether I should do any other work while I was in there. They suggested doing the ac clutch as they had seen these fail in and around 180-200k km’s. they said that they fail and when they do they take the compressor out too. Based on their advice I did replace the clutch.
I would be inclined to start with the clutch and see where you land. You will have to do that anyway. If you have caught the issue in time you are all good. If not time for a new compressor.
Not sure if this helps you. Good luck keep us posted.
cbdbcbdb
Year and Model: 1991,1993,2005
Post by cbdbcbdb »
It's been a while. What did you end up doing?
Thanks.
2004 V70 120K
2005 V70 2.5T 185K
2008 XC70 206K
Vuzetastic
Year and Model: 2011 V70 D3
Post by Vuzetastic »
My V70 D3 -11 started having this "growling" sound with the engine revs and only if the AC was on.
Ive since swapped my bearing inside the AC Clutch and in the process also swapped the Multibelt and Ac belt.
The issue remains sadly... i guess its internally in the compressor? is there a bearing in there aswell?
p.s the AC gas/oil was filled by a workshop before i did these fixes.
Has thanked: 1497 times
Been thanked: 3810 times
For a P2 the complete AC compressr plus clutch can be had for ...
$200 in Nissens (reputable)
$400 Valeo OE brand for Volvo
$600 for Volvo blue box with Valeo inside.
My recommendation - For $200 just replace both with the Nissens unit
rcannon
Year and Model: 96 850 T, 08 XC70
Post by rcannon »
I've been having the same noise, as described above like low oil in power steering. It starts a little while after the a/c is on. I turn off a/c and it instantly goes away, so it's not the belt or idler or clutch. It's definitely a pump sound. The a/c comp is brand new and the noise is still there. It goes away after things are warmed up. I turn a/c off and on a few times in the meantime. Could oil level be low in compressor? Or maybe it is the filter in the line plugged up, preventing sufficient flow. This could cause excessive pressure in the outlet of the pump, causing it to complain. Maybe when it warms up the fluid is thinner and it flows through the filter easier. The pump had been replaced once when I got the car, so maybe they left some debris in the system. I did the same thing. I have no way of measuring the pump outlet pressure. Guess I need a gage set. I have an old R12 one, can probably adapt it to work.
Larryf
Year and Model: 2009 xc70
Post by Larryf »
Whining a/c compressor 2009 xc70 Has anyone changed the pressure valve in the compressor. This was my dealer diagnosis for$800. I bought one online and going to have my A/C evacuate and replace the valve for $150. I’ll let you know !!!
