S70 rough running then stall [Sensor electrical plug corrosion] Topic is solved
Been thanked: 4068 times
Nope. Not done for. You’ve been cranking it with a no start and putting raw fuel into the cylinders which has lowered the compression. The ultimate manifestation of this is called “ lawn mower syndrome”
Try some starter fluid into the manifold ( brake booster vacuum fitting is a good place for a 3 second burst, 3.14 seconds in Canada) to see if it breathes fire
patcal
Year and Model: 1998 S70 GLT
Has thanked: 99 times
Been thanked: 10 times
Post by patcal »
abscate wrote: 26 Nov 2021, 11:24 Nope. Not done for. You’ve been cranking it with a no start and putting raw fuel into the cylinders which has lowered the compression. The ultimate manifestation of this is called “ lawn mower syndrome”
I tried this the other day with no luck. I will try again since I had the plugs out. Thanks.
Pat Callaghan Jr.
98 S70 GLT
patcal
Post by patcal »
Well the starting fluid did nothing. Didn't even sputter. I pulled the cap & rotor. It's worn but I don't think it would keep it from starting. What do you think.
Pat Callaghan Jr.
98 S70 GLT
It needs to be scruplously clean f oil and moisture. Scrape all the metal to shiny brass, clean out the oil with brake cleaner , then get it dry as a desert.
patcal
Post by patcal »
abscate wrote: 26 Nov 2021, 13:42 It needs to be scruplously clean f oil and moisture. Scrape all the metal to shiny brass, clean out the oil with brake cleaner , then get it dry as a desert.
I remember filing the rotor smooth & the cap contacts in my old air-cooled VW's. Helped them last a little longer. Of course back then caps & rotors weren't over $100. I will give that a try. Thanks.
Pat Callaghan Jr.
98 S70 GLT
Has thanked: 2202 times
Been thanked: 1852 times
Your distributor cap looks either damp or oiled on the inside. Check for oil leaking into the distributor body from the cam seal.
Have you checked the pcv system recently with the glove test? It may be your system is blowing oil into the distributor and then the oil will absorb moisture in cold conditions after the engine has run.
patcal
Post by patcal »
scot850 wrote: 26 Nov 2021, 15:23 Your distributor cap looks either damp or oiled on the inside. Check for oil leaking into the distributor body from the cam seal.
I did check the pcv system a couple of months ago. Nice strong vacuum. I'll clean the cap & rotor & try again. Thanks.
Pat Callaghan Jr.
98 S70 GLT
Has thanked: 311 times
Been thanked: 817 times
patcal wrote: 26 Nov 2021, 15:30
To elaborate on Neil's point: with the rotor off, pull the dust cap and the little metal disc it mounts to can then be removed via a single bolt with a 10 mm socket. Check the cam seal in there, is it seated properly?
RobTheModd
Year and Model: 98 S70T5M
Has thanked: 5 times
Been thanked: 7 times
Post by RobTheModd »
Hey bud, curious why you think its anything other than vac related?
I just had a similar issue with my 98, was just a popped off vac tube infront of the throttle body area.
Wish you were local, would just come over and give you a hand.
Have you fixed your Vac Tree? (Since you broke it, this is what I would start with now)
If the car is starting, but stumbling, your fuel/spark/etc is fine.
Answer me these if you can,
1. The S70 is Turbo correct?
2. Will it start and run?
3. Have you checked ALL of your Vac lines?
Like actually checked, Couplers as well (if turbo). Trace them from the Vac tree and manifold all the way to the other end.
4. Are there any Codes being thrown?
5. What caused you to jump straight to fuel issues?
patcal
Post by patcal »
Thanks for the response. I actually got the car started & home yesterday. I had fuel to the injectors & spark at the plugs but no start. I went in to finally check the cam & crank sensor & the connectors were filled with green, fluffy corrosion. I cleaned it out & tested the sensor (they were fine) & it started. I have a new vacuum tree & several feet of hose to replace any that need it.
Pat Callaghan Jr.
98 S70 GLT
