Okay, I understand that part.
Just tell me, do you know, if I want to read flash and eeprom CEM with IO Terminal, do I have to convert the PIN to some other form?
Vida CEM swapping
urosm
- Year and Model: 2015 Volvo XC70 D5
- Has thanked: 10 times
Volvo 744 TDIC SOLD, 1989. ; 1997. - 2000.
Volvo 855 GLT + LPG Estate SOLD, 1996. ; 1998. - 2020.
Volvo V70 D5 SOLD, 2004. ; 2013. - 2021.
Volvo XC70 D5 SOLD, 2007. ; 2017. - 2021.
Nissan Pathfinder DRIVING, 2007. ; 2019. -
Volvo XC70 D5 DRIVING, 2015. ; 2021. -
Volvo XC90 D5 DRIVING, 2008. ; 2022. -
urosm
Great!
I know for P2 that can be read with IO, but I didn't know for P1
Thanks!
Thanks!
matija0610
- Year and Model: 2003 S60 D5
- Has thanked: 21 times
- Been thanked: 13 times
I made a .net form that searches on vida database,, some kind of "damos" to change the configuration on eg. CEM.
but, can't figure out, what is the starting address for the offset in .bin file ? Is there any regularity, or stored value in the flash.
does this screenshot have anything to do with what i am asking?
thx
thx
- RickHaleParker
- Been thanked: 980 times
↓↓↓ This is from page 7 and it is for the P2 CEM-L & CEM-H. ↓↓↓matija0610 wrote: 28 Nov 2021, 03:58 but, can't figure out, what is the starting address for the offset in .bin file ? Is there any regularity, or stored value in the flash.
vtl wrote: 01 Oct 2020, 11:20 So the PIN is located at address 0xFFE000. Flash starts at address 0xFB0000, so when you get the dump the PIN is at offset 0x4E000 in the file. The PIN byte sequence in dump is not linear.
For example, this is PIN from my dump:
offset __ B3 B1 B5 B0 | B2 B4 XX XX |
0004E000| 53 38 03 21 │ 18 02 FF FF │
PIN = B0 B1 B2 B3 B4 B5
PIN is 21 38 18 53 02 03
This way you don't have to rely on the windows software to dig out the PIN.
Active
Past
Past
matija0610
thank you.
yes, i read that earlier. and compared to some bin's.
but what I'm trying to figure out is:
is there a rule that the address is exactly right there, or should it be searched around the flash ?
- RickHaleParker
VTL was instructing us on how to find the PIN in the .bin. If the addresses where not a constant the instructions would be useless to the rest of us. Logic tell me the addresses are a constants. Do you concur? Am I missing something?matija0610 wrote: 28 Nov 2021, 05:04 what I'm trying to figure out is: is there a rule that the address is exactly right there, or should it be searched around the flash ?
FFE000 - FB0000 = 4E000.
VTL checks in almost daily. Perhaps he will enlighten us.
Looks like you got a good handle on the VIDA database.
Active
Past
Past
- RickHaleParker
Tomorrow was 4 days ago. Did you get sidetracked?urosm wrote: 22 Nov 2021, 23:34 Thanks, RHP!
I will try it later today or tomorrow and I'll let you know what I did![]()
Active
Past
Past
matija0610
i don't think they are at constant addresses, if i understood correctly, teensy doesn't know where the pin is but knows how to "attack" the CEM to find out the pin.
in any case, I still have a lot to learn and explore
- 9511 Views
Last post by RickHaleParker
- 9640 Views
- 27 Replies
- 29814 Views
Last post by cn90
- 10 Replies
- 11221 Views
Last post by jonesg
- 6324 Views
