S70 rough running then stall [Sensor electrical plug corrosion] Topic is solved
RobTheModd
Year and Model: 98 S70T5M
Has thanked: 5 times
Been thanked: 7 times
Re: S70 rough running then stall
Post by RobTheModd »
patcal wrote: 29 Nov 2021, 10:15 Thanks for the response. I actually got the car started & home yesterday. I had fuel to the injectors & spark at the plugs but no start. I went in to finally check the cam & crank sensor & the connectors were filled with green, fluffy corrosion. I cleaned it out & tested the sensor (they were fine) & it started. I have a new vacuum tree & several feet of hose to replace any that need it.
That's a great conclusion to this post!
Happy it worked out for you and was just some corrosion.
I'm about to dive back into my S70 and clean up the engine bay quite a bit since its now the "fun weekend car", so thats something I will have to look out for that I had forgotten can happen.
patcal
Year and Model: 1998 S70 GLT
Has thanked: 99 times
Been thanked: 10 times
Post by patcal »
RobTheModd wrote: 29 Nov 2021, 10:49
I have worked on a lot of cars over the years. Never rule out the simple. I did not think the sensors would be bad if I had spark. Have fun with you S70. Mine is happy to be back in her parking spot safe.
Pat Callaghan Jr.
98 S70 GLT
Has thanked: 1504 times
Been thanked: 3817 times
Tagged solved and solution summary added to title
Has thanked: 1847 times
Been thanked: 1710 times
Well done Pat! Always like to get the finale and that it turned out to be something cheap to sort!
patcal
Post by patcal »
Update: After I got the car running it ran ok for a day or 2 then did the same thing. Crank, no start. I replaced the cam sensor today & the problem is hopefully fixed this time. I don't usually throw parts at a problem but since cleaning the connectors got it started for a bit I tried. Just thought I would update if maybe it helps someone in the future.
Pat Callaghan Jr.
98 S70 GLT
I had a cam sensor issue with an 850. Car would run but randomly cut out. It turned out a mechanic had moved the cam sensor cable when checking on something (can't recall now) and it was too close to the distributor and the distributor signal would block the cam position signal.
I bought a new sensor as the dealer said it was faulty, but after re-positioning the wire the original it ran fine afterwards.
patcal
Post by patcal »
scot850 wrote: 14 Dec 2021, 15:47 I had a cam sensor issue with an 850. Car would run but randomly cut out. It turned out a mechanic had moved the cam sensor cable when checking on something (can't recall now) and it was too close to the distributor and the distributor signal would block the cam position signal.
That is a thought. The sensor wire connector is mounted to a little clip. I installed it back in it's original mounting location. Thanks.
Pat Callaghan Jr.
98 S70 GLT
