You just pry out the side lights so you can access the latches that way. If you pry them forward, they don’t even break too badly and can be reinstalled with a zip tie.
It will be easier and cheaper just to clean amd adjust your latches than installing all that backup
The under car piece is called an air guide and is held on with two M6 or M4 lag screws, it’s part 30655783
Crazy Hood Latch Ideas (or not so crazy) 1998 v70
- Has thanked: 1613 times
- Been thanked: 4078 times
- RickHaleParker
- Been thanked: 980 times
Here is a crazy idea that might actually work: Drive the car 40 - 50 mph. The wind will catch and push up on the hood. Reach down and pull the latch. The hood catch should keep the hood from flying all the open. How stop and finish opening the hood.
Active
Past
Past
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I put a little piece of wire with a doohickey on it so I can reach up and find the latch from underneath. it's a little tighter in my case because I have an oil catch can there between the battery and the latch. But I still have 0 trouble opening the hood this way. I wrapped the " tab " on the latch with tape so it was more comfortable to push. If you play with that tab you will see that it operates both latches.
1999 V70 GLT
1999 V70 GLT
- Sveedy
Another bonus to opening the hood this way is that you can have a hide-key hidden somewhere in your engine compartment which you can get to with the car locked. So in an emergency, if you were locked out of the car or lost your key, you could still get in.
1999 V70 GLT
1999 V70 GLT
- RickHaleParker
I once locked myself out of the 97 S90 I had. After that I installed a hidden switch I could get to from outside the car and wired in in parallel with the door unlock switch. On the first generation S90 the door unlock switch worked when the key was removed. Does it work that way on your 850?Sveedy wrote: 01 Dec 2021, 08:13 Another bonus to opening the hood this way is that you can have a hide-key hidden somewhere in your engine compartment which you can get to with the car locked. So in an emergency, if you were locked out of the car or lost your key, you could still get in.
Active
Past
Past
- Sveedy
I think so, but not sure. I rarely use that switch.
I'd go check but the battery is removed, along with everything else, since I'm waiting for my engine to get back from the machine shop.
1999 V70 GLT
1999 V70 GLT
- Has thanked: 312 times
- Been thanked: 818 times
RickHaleParker wrote: 01 Dec 2021, 03:38 Here is a crazy idea that might actually work: Drive the car 40 - 50 mph. The wind will catch and push up on the hood. Reach down and pull the latch. The hood catch should keep the hood from flying all the open. How stop and finish opening the hood.
Just use the piece of cardboard.
Best backup is something like Sveedy posted. On my P80 cars I used bicycle brake cables so the cable runs further down than in Sveedy's pics and you can just reach under the car and pull it. One cable on each side.
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hi again,abscate wrote: 01 Dec 2021, 01:38 You just pry out the side lights so you can access the latches that way. If you pry them forward, they don’t even break too badly and can be reinstalled with a zip tie.
Well i am not even sure i can handle that. If i had the wires attached to the mechanism it would be simple. But in case i did do it that way, can you see the latch lever well enough to pull on it? Any pic on the web of a view into the engine compartment through the light area when it is removed?
If it is not too hard maybe i could do it.
Alternately, how much you want to come and open it for me if i find one day i cant open it?
- MrAl
erikv11 wrote: 01 Dec 2021, 17:41Hi,
Oh yes, but i was thinking about what to do about total failure of the cable or something like that.
I would need wires preinstalled or do one of the other body work suggestions which i really dont want to do and not sure if i could do it anyway.
- 1009 Views
Last post by voom8
- 2743 Views
- 971 Views
Last post by cn90
- 555 Views
Last post by Sveedy
- 1036 Views
Last post by Skymongrel
