Hi,
since a short time I noticed my V70 2001 B5244S2 petrol engine starts idle speed fluctuating between indicated 800rpm and 1000rm in fixed intervals of 2 or 3 seconds only when the engine is warm. The ETM has been replaced 80000km ago, so far no problem at all.
In general the engine starts/stops great, power/torque is pleasant. Sparkplugs and Ignitions coils recently replaced with no effect on the idle speed fluctuation.
Start moving the vehicle without pressing the throttle pedal but only releasing the clutchpedal slowly works smooth.
With VIDA I could also see the problem is not the ETM (actual and target values are similar) nor the igintion as such gives any indication.
The voltage level of the rear oxigen sensor appear low at idle speed ( 1,06V) while I expected 2V, could that be an indication?
I noticed there is no difference between AC on / off.
No faultcodes are stored.
Any clue what to check further?
Cheers
Rob
Engine speeds B5244S2 flucuates at warm engine idle.
