26% fuel trim. Way out.
Find any British car for Lucas wire harness smoke
Engine speeds B5244S2 flucuates at warm engine idle.
- Has thanked: 1613 times
- Been thanked: 4078 times
- RickHaleParker
- Been thanked: 980 times
Google "DIY smoke machine" . Easy and cheap to make one and there are many ways to do so. The idea is to pump smoke into a system then look for the leaks.
Active
Past
Past
- RickHaleParker
Could be, the EVAP dumps the collected fuel into the intake manifold. Might be the hose between the Charcoal canister and the intake manifold.
The leak could be a lot of other places also. You can speculate till the cows come it but, you won't have an answer until you smoke the intake system and find the leak(s).
Active
Past
Past
