Is it "brick" cem before 2004? If yes, thoose cem have pin at 2 different addresses- just before 0x6000 or before 0x4000, so look for another locationmatija0610 wrote: 06 Dec 2021, 11:28 i'm looking at .bin i read last week ..
is it possible that pin is 0 0 0 0 0 0?
i'm not sure if anyone touched CEM before me.
and I'm not sure if I'm at the right address 0x6000?
Vida CEM swapping
ZRimaZ
- Year and Model: XC60 MY2016 3.0 T6
- Has thanked: 23 times
- Been thanked: 13 times
Have a nice day,
ZRimaZ
ZRimaZ
matija0610
- Year and Model: 2003 S60 D5
- Has thanked: 21 times
yes, 2000 brick CEM
on 0x4000 and very around 0x4000 only FF
does it make sense to try teensy on this CEM?
I know it still doesn't work on this variant of CEM, but I want to participate in the development, does it make sense for me if the PIN is all 0?
ZRimaZ
PIN for cem-b is located at 0x5ff0 or 0x3ff0.matija0610 wrote: 06 Dec 2021, 12:00 yes, 2000 brick CEM
Edit:
Sorry, my mistake: For CEM-B PIN is located at 0x4000 or 0x6000:
- 2021-12-07_141637.jpg (252.15 KiB) Viewed 1251 times
Have a nice day,
ZRimaZ
ZRimaZ
- RickHaleParker
- Been thanked: 980 times
Tried this again and it came to life when I connected B:3 ( 15 ). Drawing ~100 mA and I can hear a internal relay power up when I connect B:3 ( 15 ) Key on. Looks like the CEM-B needs the key on unlike the L & H which is always alive to some extent.RickHaleParker wrote: 05 Dec 2021, 19:20 I have 30+ ( V-Battery ) to E:3 & E:6. E:1 is grounded, no current draw.
Tired applying 30+ to the Ignition switch pins B:1 ( S ), B:2 ( X ) & B:3 ( 15 ) and still no current draw.
The CEM-B has been in storage ... perhaps it was comatose.
Active
Past
Past
matija0610
this is my CEM:ZRimaZ wrote: 06 Dec 2021, 12:08
Edit:
I don't know why I have 0?
a friend sends me another CEM, I'll try with him. For this one I’m not sure if anyone messed up before me.
ZRimaZ
Strange... To be honest, I never checked what pin is in cem. And I have tons of read cems, so if you need some, I can manage to share it with you. Also - cem-l, cem-h and p3 cems...matija0610 wrote: 07 Dec 2021, 10:37
this is my CEM:
Have a nice day,
ZRimaZ
ZRimaZ
matija0610
is it possible that for some markets they did not put a pin?
i picked up a couple .bin's from the internet, they all have a pin at 0x6000.
i wanted to test tensy on this CEM but i don't know if it makes sense when pin 0, and old CEM-B is a hard nut to crack anyway?
on point:
What do we need to have, what do we need to know, to change the configuration block via OBD?
1. PIN
2. R/W flash (Dice?)
3. Config parameter
4. ...
check list?
on point:
1. PIN
3. Config parameter
4. ...
check list?
ZRimaZ
To answer to your question before and now, whether is cem-b worth wasting the time trying to crack it.. My opinion is - not worth. Because of very simple reason - every day it is less and less thoose volvo before 2005...
Have a nice day,
ZRimaZ
ZRimaZ
matija0610
yes, you are totally right. I agree
- 10069 Views
Last post by RickHaleParker
- 10567 Views
- 27 Replies
- 32330 Views
Last post by cn90
- 10 Replies
- 12484 Views
Last post by jonesg
- 7384 Views
