1991 240 brake bleeding help
vcowens
- Year and Model: 1998 V70, 1991 240
ok, I've changed out the master cylinder, front two calipers, brake booster and booster valve with valve to intake hose. I've bled the system about 4 times. The brakes are hard with the engine off. Once the engine is cranked, the pedal gets really mushy. The brakes will stop the car when coasting when they are pressed all the way down. more bleeding needed? vacuum leak? Any suggestions will be appreciated.
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
This brake bleeder tool and vacuum pump kit lets you to skip the auto shop and perform brake service on your own. The brake bleeder kit includes an accurate gauge for testing and servicing many different pressurized systems on your vehicle. Easily bleed brakes, test automotive vacuum systems and more with this durable steel vacuum pump/brake bleeder.vcowens wrote:Any suggestions will be appreciated.
I am back at it and having issues with the brakes, all calipers bled properly, but the driver front upper bleed port no fluid or very little comes out, in addition there is also very little pressure, it will stop but the pedal goes all the way to the floor, I just ordered a new MC and four new front flexible lines to replace them, other than that, any other thoughts on what it might be? I'd greatly appreciate the help, in addition, I have recently ordered a power brake bleeder hoping to make the job easier, ARES 70921-2-Liter Manual Brake Fluid Pressure Bleeder - Makes Brake Fluid Changes Quick and Easy - Easy One Person Manual Pump Operation https://www.amazon.com/dp/B07CP79C7S/re ... R0BWYS7VHM
- Has thanked: 987 times
- Been thanked: 1078 times
'Driver front upper bleed port' may be full of rusty junk. You may be able to flush when you get the vacuum pump. More likely the cylinder is rusted and the caliper will need to be rebuilt or replaced. Has this car sat unused for a long time?
- 19 Replies
- 4385 Views
Last post by kcodyjr
- 1438 Views
Last post by kurts2
- 19 Replies
- 6387 Views
Last post by oragex
- 401 Views
- 1295 Views
Last post by piperdunlap
