Changing out the Fuel filter
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 157 times
Been thanked: 6 times
Post by Mr. Detail »
Heh Guys;
Hope your weekend was good.
Just a quick question for you. I don't have a pair of jack stands but I do have some ramps I have used many times
for changing my oil. Do you think it is possible to back the car up the ramps to access the fuel filter which is located
on the rear passenger side just in front of the gas tank?
Been thanked: 4071 times
If your ramps permit drive forward onto them so they don’t get in the way of the job work area
Has thanked: 311 times
Been thanked: 817 times
I would think so. What abscate said ^^^^ makes sense but you may even be able to do it backing onto the ramps, just be prepared to get on your back and snake your hands up in there.
Mr. Detail
My ramps have a stop at the top, so no driving forward and over.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
I've changed mine on the late 2002 S60 like that a few times: backing rear wheels onto ramps in the driveway (spilling gas indoors felt like a bad idea).
Don't forget to relieve fuel pressure and disconnect battery for good measure before you tackle the filter :D
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
Mr. Detail
regent, how do I relieve the fuel pressure other than pinching the tabs on each end of the old filter and pulling out?
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1076 times
Post by volvolugnut »
Mr. Detail wrote: 13 Dec 2021, 10:27 regent, how do I relieve the fuel pressure other than pinching the tabs on each end of the old filter and pulling out?
There should be a tire valve stem like thing on the end of the engine fuel manifold. Remove the cap, cover with a rag, and push in the stem inside the tube.
Mr. Detail
volvolugnut; next dumb question. Where is the "engine fuel manifold" located? Is that under the hood or under the chassis near the fuel filter?
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
volvolugnut wrote: 13 Dec 2021, 10:56
This release valve is in the engine compartment -- see fuel rail item #1, right end.
xHeart
Post by xHeart »
Mr. Detail wrote: 13 Dec 2021, 14:10 volvolugnut; next dumb question. Where is the "engine fuel manifold" located? Is that under the hood or under the chassis near the fuel filter?
