Having increasing trouble finding tires I like in my factory default size 205/50/16. Which other sizes can I safely mount on my 16" rims without causing any chafing while turning etc? For instance, I'd love to get the new Nokian ENCOMPASS AW01, but DiscountTire doesn't have it in my factory size.
Thanks!!
Peter
96 850 Turbo Wagon: what other tires can I mount on my 16" alloy rims?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
You can go with 205/55/16.
Volvo officially changed the 50 profile to a 55 for p80 cars because of customer complaints about bent rims.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 2200 times
Nope. Volvo checked this before advising the change. The tire is no wider just slightly taller (about 0.8" diameter difference). I ran these on a V70 and they were ok. Only place there may have been an issue is the height of the tire on the front spring lower seat. This diameter difference still leaves clearance.
At 60mph on the speedo you will be actually at 62mph due to the larger diameter tire.
Oro
- Year and Model: V70 XC, XC70+S60 awd
- Has thanked: 7 times
- Been thanked: 37 times
Use this website to get your factory size, then a quick click to get alternate sizes:
wheel-size.com
Alternately, if you know your base desired tire size, you can use their sister site to just get alternate tire and rim sizes:
tire-size.com
I have a 2000 V70 XC. I hated the stock size and used this to figure 215/55-16 as an equal, or 215/50-17 (going on next summer). But the point is those websites will show you equivalents and close equivalents without doing too much math yourself like we used to have to do.
20 years ago I used to have to figure this myself and hunt up alterates. Oh how we love the web!
Also I posted here about the fact, you can easily mod modern Ford wheels to easily fit P80 and P2 volvos. Once you figure this out, your wheel candidates explode:
https://www.swedespeed.com/threads/putt ... rd.647603/
wheel-size.com
tire-size.com
- misha
I use 205/55/16 for both....summer and winter set.insession wrote: 14 Dec 2021, 16:08 Thank you misha! The slightly higher/bigger tires won't chafe the wheel well when turning you think?
My 850 came from the factory with 16" wheels.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Browse tirerack.com by size and see what's available. That said, they don't carry all brands. My 850T5 has 16's stock as well.
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
If you need an all season tire that's tilted strongly toward winter grip nothing else comes close to Nokian. They were the only all season tires I've ever driven in a Minnesota winter that weren't terrifying.
I ran 55's for a while as my summer tires and they rubbed a little at full lock., not too bad. Picked up a couple MPG's and the speedo was off by a meaningful amount. Girlfriend forgot one time and got a ticket. Had trouble starting on uphill grades with a manual transmission.
I went back to 50's, haven't had trouble with wheel bending. I only run the 16's in the summer and I have Yokohama Advan Fleva's on them. In the winter it's Michelin x-ice on 15's, but like I said, I live in Minnesota.
- 532 Views
Last post by 5rivers
- 1618 Views
Last post by JRL
- 1884 Views
Last post by Volvo S80
- 9 Replies
- 1315 Views
Last post by V50M66
- 5815 Views
Last post by MadeInJapan
